Help
Old Aug 9, 2021 | 12:26 AM
judie bootie's Avatar
judie bootie
4wd Low
Help
Help how do I install new wiring harness where do I start
Old Aug 9, 2021 | 09:25 AM
FordEdsel75's Avatar
FordEdsel75
It goes under the dash. Drivers side feeds to left headlight and to rear taillights. Passenger side feeds right headlights. Under dash branches off to various switches. If it's a kit like American Autowire you have to read the directions.
Old Aug 9, 2021 | 10:52 AM
Jetfixer-6's Avatar
Jetfixer-6
Judging from your "where do I start" sentence I'll assume you have not done this type of work in the past? I would hit youtube hard before embarking on such an endeavor. Plenty of vehicles burned to the ground from incorrect or improvised wiring. Way too much instruction required to try put into words in a post
Old Aug 9, 2021 | 11:42 AM
judie bootie
4wd Low
Help
Thank you, I guess I'll just start with fuse box. Have a great day
Old Aug 9, 2021 | 09:37 PM
jgavac's Avatar
jgavac
It will help to source a wiring diagram for your specific year and flavor of truck. Then, when you get your replacement harness I would lay it all out on a big table or the floor somewhere (where you can have it for a while and not step in it/have to move it), and work through each run of wire and label each plug with some tape and a note about what the plug is for. Also make sure you have like for like plugs before swapping to make sure your harness will plug in properly. Putting in the time before you actually try and start shoving wire in the truck will help in the long run.
If there's still some kind of factory harness, I wouldn't rip it out until you've done all the above steps, so that way routings are fresh in your mind. Take pictures of how bundles of wire get through the firewall, etc and make notes to refer to later. Don't hack up the old harness as much as possible for reference.
Old Aug 10, 2021 | 06:03 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X1000 on what jgavac said. Lay it out make sure it is all there labeled/correct elec connectors. Do not be in a hurry.
Great color diagram https://www.classiccarwiring.com/197...iring-diagram/
My elec diagrams start here thread #8 and scroll and into thread #10
https://www.ford-trucks.com/forums/1...l#post14696841
texanranger
Electrical Systems/Wiring
Mar 16, 2009 07:05 PM
mik369
2004 - 2008 F150
Aug 16, 2007 04:05 PM
Ranger_351w
Nov 16, 2004 07:59 PM
shortbed1
Mar 16, 2004 07:01 PM
showtime946
Jan 19, 2004 11:18 AM
