Cooling issue, please help
Old Aug 17, 2021 | 06:35 PM
  #31
DaltJo2000's Avatar
DaltJo2000
I don't have any experience with these 6.7L's, but I CAN say this.
K.I.S.S - Keep It Simple Stupid. Start with the small things, another fellow said thermostats, seems unlikely that both would go bad, but I assume they're cheap fixes and would start there. I can't tell you how many times something was acting ( they function, just acting abnormal ) up with my vehicles and I immediately assumed the worst, replaces an expensive item or something that was off the wall, only to figure it out later that it was a very simple fix...
Old Aug 17, 2021 | 09:39 PM
  #32
Tsubakihara's Avatar
Tsubakihara
Originally Posted by HRTKD
Could be. Since the engine oil and transmission are on different cooling systems (primary, secondary, respectively) would that require both thermostats to go bad?
Second time I’ve mentioned it. Revisit the recent flush for air. Tranny and engine oil hit 240+ in these trucks.
Old Aug 18, 2021 | 05:05 PM
  #33
gascan's Avatar
gascan
Thanks for the reminder.... I do have a question... How would one check for such an issue?
Old Aug 18, 2021 | 05:14 PM
  #34
HRTKD's Avatar
HRTKD
The only way I know how to do it without a vacuum tool, is to park the truck on an incline (the steeper the better), open the cap on the radiator and get the engine good and hot. Don't start with a hot engine, of course, since opening the radiator cap on a hot engine is dangerous. The air will come out the top of the radiator. After you don't see bubbles for a while, you're done.
The recovery tanks in these trucks are pressurized, so that may be an alternate way, but I have no experience with that.
If anyone can recommend a good vacuum tool that works with multiple brands, I would be interested in buying a tool.
fluidp
Aug 7, 2015 08:04 PM
7racecar7
Modular V10 (6.8l)
33
Jul 13, 2014 07:15 PM
jleal_21
Aug 15, 2012 06:40 AM
tjc transport
31
Mar 21, 2011 06:22 AM
