Speedometer lubin' - looking for pointers
Old Aug 5, 2021 | 05:33 PM
FuzzyBeanBag's Avatar
FuzzyBeanBag
Lightbulb Speedometer lubin' - looking for pointers
Some of you may have seen my previous post about my speedo being toast. While I am awaiting a replacement, I took the original out to try and figure out what preparation I should do with the replacement before slapping it in; I really do not want to go through it even again after it goes in, hah!
From the looks of it, there's not much to lube... the speedo cable spins a center mass (I guess that's the magnet) that then moves the needle to the proper position. I can't really see any visible bearing or gears so I assume it's just a direct connection type of a thing. The odometer has a few plastic gears and I can only see one spot with what could potentially be grease/lube? In any case - please see pix. I guess the three questions I have are:
* What lubricant to use? Lithium grease? Or maybe gun slider grease?
* Should I put anything into the cable socket on the speedo?
* Anything to lube for odometer gearing or the speedo needle?
Thanks
Old Aug 5, 2021 | 10:24 PM
Christmas's Avatar
Christmas
I would choose something that won't run or dry out . Clock grease comes to mind.
clock grease | eBay
Old Aug 6, 2021 | 06:10 PM
scottscott's Avatar
scottscott
I use a light synthetic oil to lube speedos. I apply it with the end of a toothpick.
Set the speedo head face down, put a drop on the part where the speedo cable plugs in. Let it sit for a little while to let the oil run down into the bushing. Spin it some to help the oil work in.There is a bushing where the speedo needle shaft goes thru the body, it gets a tiny drop. Tiny drops on all the spots where a shaft for the odometer comes thru the body or a bushing. Wipe off the excess when you are done. I spin the speedo wit the end of a cable & a drill for a while after lubing to make sure there are no problems before I install them in restored clusters.
Old Aug 6, 2021 | 11:54 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
1cc's of unicorn tears ought work just fine. Or what scottscott said sound pretty good also.
Old Aug 7, 2021 | 12:15 PM
HoustonDave's Avatar
HoustonDave
This is a pretty good write-up of repairing Brit speedos, the general principles and lubing probably cross pretty well.
https://redirect.viglink.com/?format...eedorepair.pdf
Old Aug 8, 2021 | 01:40 AM
FuzzyBeanBag
Thanks everyone
For light synthetic oil - something like this would work?
Amazon Amazon
Gonna buy locally but just wanted to confirm. Thanks!
Old Aug 8, 2021 | 02:52 AM
Christmas's Avatar
Christmas
The problem with oil is it does dry out over time. Silicon grease/oil won't do that.
Old Aug 8, 2021 | 06:20 AM
scottscott's Avatar
scottscott
The oil you linked to should be fine.
Old Aug 8, 2021 | 06:58 AM
XSoph's Avatar
XSoph
I cleaned everything with compressed air and used a dab of silicone lube that advertised as leaving a dry film. It's still spinning great after several months. I think I used WD 40 brand specialist silicone.
Old Aug 9, 2021 | 01:53 AM
FuzzyBeanBag
Thanks for the feedback!
FuzzyBeanBag
20
Mar 10, 2021 12:47 PM
Muppy1840
Mar 12, 2016 09:57 AM
Nate414
Nov 11, 2011 10:59 AM
polarspeed
Mar 14, 2010 07:01 PM
strokerfe
Dec 18, 2006 04:55 PM
