I do not have power to my 12 volt outlets on the front and rear consoles. The usb port works. I’ve used a multimeter and do not pick up any power. The fuses under the hood look fine. I pulled one and tested and it is good. What am i missing?
2019 F350 LT
Yes sir the ignition is on. The manual does not show any of the passenger side fuses related to the 12 volt outlets. I'm looking for "power point". I don't seem to have anything else not working on the dash or interior.
I'm looking in my wiring diagram book and I do not see where any of the power points are fed from the passenger footwell. All of them come from the Battery Junction Box under the hood.
Power Point - Dash Panel - C2033 - Fuse 64 - 20A
Power Point - Inside Console - C3063 - Fuse 66 - 30A
Power Point - Rear Of Console - C3323 - Fuse 70 - 20A
USB Charge Port - Inside Console - C3522 - Fuse 68 - 20A
