302 performance loss
Old Aug 4, 2021 | 04:04 PM
mudymax's Avatar
mudymax
I have a 1989 f150 with a 302 v8.I have been having engine issues ever since I installed a 6in lift and the U joint gave out causing the driveshaft to fall out and break/bend the transfer case and transmission.
I have installed new cap,rotor,wires,spark plugs and the part that the middle wire on the cap connects to,sorry I forgot what it is called.it will dial ok but has no power and try’s to die when I push the pedal.it hardly makes it up hills and has smoke coming from the engine oil cap.can anybody help?
Old Aug 4, 2021 | 05:20 PM
85e150's Avatar
85e150
Welcome to FTE! Let's start a new thread.
Did the engine performance decline after the lift or after the u-joint broke? Did the engine over rev as a result of the u-joint? What work was done to the engine prior to the issues? How did it run before the lift etc?
With your 6 inch lift did you install larger tires? If so, what size?
Break and bend the transfer case and transmission? Are those replaced?
You have a lot of stuff going on here, including the possibility that your engine is worn out.
Old Aug 4, 2021 | 05:31 PM
mudymax's Avatar
mudymax
1989 f150
it ran fine before the u joint gave out and it used to rev very high when first started for about a minute before u joint but now it doesn’t even do that.I had just bought the truck and didn’t touch the engine becaus it ran ok.I have replaced the 4 speed transmission with a 5 speed and swapped out the transfer case and extended tail end housing same tire as stock
This is the truck after the lift kit
Old Aug 4, 2021 | 11:22 PM
85e150's Avatar
85e150
Did it over rev due to the failure?
Since nothing you did improved things, it suggests some internal damage like bent valves or a hole in a piston. Does it run smoothly but have no power, or do you have a rough idle and a miss?
Old Aug 5, 2021 | 06:13 AM
mudymax's Avatar
mudymax
1980 f150
it’s idles just fine just no power when you put it in gear.1 or R
Old Aug 5, 2021 | 08:54 AM
85e150's Avatar
85e150
Check the timing. Pull the distributor cap and rotate the engine by hand. Once the rotor moves, reverse rotation and note how many degrees the crankshaft moves before the rotor moves. SBF timing sets wear out and you can be off a tooth and still "run". If there's much slop in that chain, it's time to replace the timing set.
stewy604
Feb 13, 2018 10:23 AM
Vince79vette
Mar 19, 2015 06:10 PM
Josh88Ford
Offroad & 4x4
May 29, 2006 08:24 PM
93BigBlackBronco
1978 - 1996 Big Bronco
Apr 7, 2004 04:58 PM
frdcowboy
Offroad & 4x4
Jan 1, 2004 09:21 PM
