Please help with an engine swap
Old Aug 3, 2021 | 11:14 AM
fiatcrew's Avatar
fiatcrew
4wd High
I have a 1981 F350 dump truck that blew a head gasket that cracked the block. This was a rebuilt 351 m and I would like to exchange the motor to keep the truck until this shortage is over and used trucks are more available. The problem that I am having is the lack of motors in 351 or 400. What would be needed to put another engine in it and which engine would work. This truck is mainly for farm work and hauling junk.
Thanks Nick
Old Aug 3, 2021 | 12:07 PM
dagwood57107's Avatar
dagwood57107
Thanks Nick
well I would check out car-part.com I have no idea where you are located, but there seems to be at least a few 351m's available. I'm in South Dakota and the closest one to me is 140ish miles away.
Old Aug 3, 2021 | 12:13 PM
Franklin2's Avatar
Franklin2
You could put any engine in there if you got the transmission with it. Or the bellhousing if it's a manual transmission. A 460 would bolt to the motor mounts. It would bolt to the 351m bellhousing but you would have to check for flywheel clearance. Or just get a 460 bellhousing if the 460 flywheel rubbed.
Whatever engine you get, just make sure it's a rear sump style oil pan.
Old Aug 3, 2021 | 09:17 PM
fiatcrew's Avatar
fiatcrew
4wd High
Thanks I was told that the 351's and 400's were just about gone. I have a manual trans so a 460 may be the way to go.
Old Aug 4, 2021 | 06:02 AM
Franklin2's Avatar
Franklin2
None of those engines are made anymore. But at least the others were stopped in the late 90's. The 351m/400 engines stopped production in the early 80's.
Old Aug 4, 2021 | 06:56 AM
5starCabF-3's Avatar
5starCabF-3
Powertrain products has long blocks.
I purchased a long block from them about 5 years ago.
I am at about 25k miles and am very happy.
Old Aug 4, 2021 | 06:58 AM
5starCabF-3
Old Aug 8, 2021 | 11:27 AM
bobs 80 f250's Avatar
bobs 80 f250
I can see from your profile that you’re in PA. I’m in the south Jersey area and have a used 351m. It’s missing some parts,but all in all a good motor. It’s your if you want it.
Drew Owsinski
Aerostar
Jan 14, 2015 04:00 AM
newoldtruck
Aug 6, 2013 10:35 PM
cda5580
Jan 24, 2010 05:50 PM
grage101
Feb 28, 2009 02:31 PM
stcguy
May 6, 2007 10:47 PM
