AC recharge issue
Old Aug 2, 2021 | 05:17 PM
AmericanPharoh's Avatar
AmericanPharoh
AC recharge issue
Hey i went to recharge my AC today and when I attached the gauge to the high end valve it was under extreme pressure and hissing as I tried to put the gauge on. I’ve yet to get it on. What does this mean? My AC doesn’t blow cold obviously
Old Aug 2, 2021 | 05:21 PM
Walleye Hunter's Avatar
Walleye Hunter
I think you're supposed to attach that to the suction end and I think they're different sizes so you can't put it on the wrong end.
Old Aug 2, 2021 | 05:22 PM
AmericanPharoh
weird because I looked up which end to attach it too
Old Aug 2, 2021 | 05:23 PM
AllaboutMPG's Avatar
AllaboutMPG
If pressure is that high system may be plugged up and that maybe why it's not working. Shut it down and let pressure bleed off attach and check again.
Walleye Hunter
My memory is not very good but I'm thinking it gets connected to a fitting on the dryer, does that sound right?
AmericanPharoh
I’m fact the gauge doesn’t even fit around the other AC port so it has to be the one I was on. Do I have the wrong gauge? Is Ford being wierd again? 😂
Old Aug 2, 2021 | 05:24 PM
AmericanPharoh
hey first of all Jesus does save I love the picture 👍🏼 Second do I just hold the thing down until there’s no pressure in it anymore?
Old Aug 2, 2021 | 05:25 PM
Walleye Hunter
I believe that they are standard across the manufacturers.
Old Aug 2, 2021 | 05:26 PM
AmericanPharoh
ok I’m doing that now. It didn’t post my first response because I was agreeing with your profile picture
Old Aug 2, 2021 | 05:28 PM
AllaboutMPG
AmericanPharoh
the gas escaping is cold so idk if something else isn’t working and I’m wasting my time
Old Aug 2, 2021 | 05:38 PM
FordTruckNoob's Avatar
FordTruckNoob
Some quick connect fittings for AC gauge sets have a **** that lets you wind the pin that depresses the valve out before you connect to the port. Make sure that **** is fully unwound first. Aside from that, low side port is on drier. High side port on tube close to the compressor. Refrigerant when released from pressure will always feel cold. It does not matter which port it gets released from.
Old Aug 2, 2021 | 07:37 PM
'88 E-350's Avatar
'88 E-350
Are you using a real gauge set or one of those auto parts store quick charge kits? Most gauge setups have a **** that you rotate counter clockwise to retract the pin that pushes the valve then crank it back down after locking it in place. If you're using the cheapo kit it might be defective or you're not unlocking it before trying to push it on. The ones I've seen have a collar you pull back to snap it onto the port, there might be other styles.
Superm1952
Jun 24, 2023 07:10 AM
paker
1997 - 2003 F150
May 5, 2021 07:10 PM
genscripter
Aug 4, 2015 03:14 PM
forkhorn
Jul 18, 2015 01:28 PM
nmarcoe
1997 - 2003 F150
Aug 29, 2013 05:20 PM
