Question about Timing Chain
Old Aug 2, 2021 | 12:31 PM
uecles's Avatar
uecles
I have a 98 Ranger 4.0 V6 with 203,000 miles that has the original timing chain and seals. It is running OK but sometimes acts up a little. I was wondering if it could be the chain is worn and how would I know it was time to change it. Does it seem like with that many miles it would be good preventive procedure to change it out even though it is running good right now? Thanks for your thoughts on this. Les
Old Aug 2, 2021 | 05:42 PM
85e150's Avatar
85e150
Is it the OHV version of the SOHC version?
Old Aug 2, 2021 | 09:09 PM
uecles's Avatar
uecles
I have the OHV engine with only one chain in the front of the engine. Les
Old Aug 3, 2021 | 12:29 AM
85e150's Avatar
85e150
If it's not making noise, run it. But you wouldn't be wrong to change it. Those have a hydraulic tensioner that helps avoid the wandering idle and other problems caused by worn components. I just sent a '99 Explorer down the road with 130k. Original plugs. It smogged perfect. Zero or minimum on every measure. Sturdy and reliable.
Old Aug 3, 2021 | 07:36 AM
uecles's Avatar
uecles
Thank you for the response. I kind of felt that way also but it is nice to know that others have the same idea. Les
d_parsley
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Nov 8, 2005 11:29 AM
KYFord
1983 - 2012 Ranger & B-Series
Jun 7, 2004 02:56 PM
Wstrombe
Jan 5, 2004 05:44 PM
newtattoobob
Sep 7, 2002 11:28 PM
