(67P) 7500 front axle?
Old Aug 1, 2021 | 11:01 PM
Bovinerazzr's Avatar
Bovinerazzr
1.Does anyone know what front axle this is?
2. What does this part mean?( Usage:
● Incomplete vehicle package – req. further manufacture and certification by a final stage manufacturer)
3. Just wondering if maybe this is holding up my order since it is “unique “. Thanks for any input.
EXTRA HEAVY DUTY FRONT END SUSPENSION – 7500 GAWR (67P)
Availability:
● Optional on F-450 or F-550
● Standard on F-600
Usage:
Not available with:
● Heavy-Service Front Suspension Package (67H), Extra Heavy- Service Suspension Package (67X)
Includes:
● (3) Unique Front Axle
— 7500 LB GAWR for 4x2 Chassis
— 7500 LB GAWR for 4x4 Chassis @ 4.30 Ratio
— 7500 LB GAWR for 4x4 Chassis @ 4.88 Ratio
● Max 7500 lbs. Front Springs/GAWR rating for configuration
Old Aug 1, 2021 | 11:16 PM
ford390gashog's Avatar
ford390gashog
It's not unique, pretty common configuration. There is plenty holding up builds but this isn't one of them. Did this truck also get ordered with the aft fuel tank?
Old Aug 2, 2021 | 07:48 AM
Bovinerazzr
No on the aft fuel tank. Do you know what axle it is?
Old Aug 16, 2021 | 06:23 PM
brosko80's Avatar
brosko80
Hi, I am thinking about ordering that same option. Maybe you could help me with some info or an opinion. Is the extra heavy duty front suspension option for a crew cab F-550 203" chassis something that can or should be ordered even though I'm not going to put a plow or anything on the front end? The trucks just going to be used for landscaping with a dump body on it. I mean can I put this option on without having any detrimental effects like the truck jumping all around from the stiff suspension and nothing on the front end? I just wanted to make it a little heavier duty. What do you think about this; if you don't mind?
nxtdiesel
Feb 26, 2017 02:36 PM
firejack8
2009 - 2014 F150
Feb 19, 2015 03:54 PM
tr2162
6.4L Power Stroke Diesel
Jun 20, 2008 10:29 PM
mike28
Jan 17, 2008 12:53 PM
derekmartin
Mar 31, 2003 05:32 PM
