Ham radio finished
Old Aug 1, 2021 | 09:25 PM
Squirrel13's Avatar
Squirrel13
Ham radio finished
Yaesu FTM400-XDR brain mounted behind the rear seat by the amp.
Power is fed from Upfitter 5 to a sub panel under the glove box.
Fabbed up custom antenna mount.
Fabbed up a magnetic remote mic
Contol head uses 67Designs mount
Old Aug 1, 2021 | 10:25 PM
ATLScott's Avatar
ATLScott
Nice setup!
Old Aug 2, 2021 | 06:04 AM
GM in a Ford's Avatar
GM in a Ford
Are you just playing the ham radio sound through the speaker on the radio? Can you hear it well enough? I currently have my FTM-400 mounted under the seat of my Wrangler and a cable going to the radio so I can listen to the ham radio through the Jeep's stereo. The nice thing about that seteup is it would play one channel through the left speakers and the other channel through the right speakers so you could monitor two at once. But I don't see any input like that on my new F250.
Old Aug 2, 2021 | 07:53 AM
JAKE65MM's Avatar
JAKE65MM
Nice setup, is that antenna 70cm and 2m?
Old Aug 2, 2021 | 08:37 AM
fireguyed's Avatar
fireguyed
Nice job on the install. But be aware, some states would consider all those devices "visual obstructions". Very subjective...
Old Aug 2, 2021 | 09:04 AM
Gary F's Avatar
Gary F
Squirrel13,
Where did you run the antenna cable through to get it into the cab.?
Thanks
Old Aug 2, 2021 | 10:58 AM
Squirrel13's Avatar
Squirrel13
Jake65nm - yes it does both 2m and 70cm
Gary F - the antenna wire sneaks in thru the power running board grommet
GM in a Ford - I used a Yaesu mls-200-m10 amplifed speaker in my Jeep. Worked so well I put in the F350
Old Aug 2, 2021 | 12:17 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
Cool
(Unless I missed it)
All that and no call sign??
Also looks good.
Old Aug 2, 2021 | 01:37 PM
Squirrel13's Avatar
Squirrel13
Also looks good.
LOL - here’s a shocker, see if anyone else gets it K9ADD
Think Doug from up
Squirrel13
Feb 10, 2022 03:07 PM
HILLBILLY BOB
Dec 4, 2020 06:09 PM
Cody Phillips
Aug 9, 2019 05:56 AM
grandmas77f150
1983 - 2012 Ranger & B-Series
52
Mar 22, 2015 08:07 AM
76f350spercamprspeal
Vehicles for Sale
Nov 2, 2012 09:19 PM
