How Do I replace a Block Plug?
Old Aug 1, 2021 | 04:39 PM
ForgivenCreation's Avatar
ForgivenCreation
Alright everyone a couple of days ago I noticed my engine was leaking coolant from above my starter. At first I thought it was the heater core based on some other threads but it ended up being the block plug right above the starter. What I am wondering is how hard are is that one to replace on the 351m and is there any tips or tricks yall have?
Thanks much and God Bless!!
Old Aug 1, 2021 | 05:21 PM
tbear853's Avatar
tbear853
Just from memory, I think once you get the starter out of your way and coolant drained, shouldn't be too difficult. I haven't done a 351M yet, but long ago on something else a hole punch (drill) followed by a nice 3/8" lag bolt let me wedge the old one enough to grab an edge with vise grips. Clean the hole, a little sealant on new plug, tap tap it in evenly.
Old Aug 1, 2021 | 05:37 PM
ForgivenCreation
Awesome, Thank you very much! I will for sure be recording a YouTube video on it.
Old Aug 2, 2021 | 11:00 AM
Light Blue Oval's Avatar
Light Blue Oval
That would be the perfect location for a block heater, if you feel the need for one...
Old Aug 2, 2021 | 02:34 PM
440 sixpack's Avatar
440 sixpack
the rubber expansion plugs are much easier to install in the vehicle.
The thing to remember now is if one goes the others could go at any time.
Old Aug 3, 2021 | 12:51 PM
ForgivenCreation
So for a block heater, does the heater sit in the coolant passage or how does that all work. Is the purpose to speed the warm up and keep from freezing or both. Also for the drain plug what is the stock size, this one has been leaking for a while and is a rusty goopy mess.
Old Aug 3, 2021 | 01:06 PM
Light Blue Oval
Engine Block Heaters (lmctruck.com) Just install in place of a regular freeze plug, add a few zip ties, and you're golden.
The 3 prong plug runs to the grill shell and plugs into household current with an extension cord.
Anyhow, yeah...we just plug it in at night if the forecast is below zero. Makes for easier morning starts in freezing temps.
Old Aug 3, 2021 | 07:24 PM
lasermike's Avatar
lasermike
I've used this tool at least 3 times, once on the Crown Vic and twice on the 390 in my truck. Would not have been able to do the one in the Crown Vic without it.
Amazon Amazon
Michael
akblackfoot
Oct 28, 2024 12:36 PM
Ambulancewarrior
Apr 30, 2019 07:23 PM
SVandal
Apr 29, 2017 01:01 AM
nickh
Feb 15, 2009 06:35 PM
beerman2therescue
Jan 28, 2008 10:38 AM
