LONG TERM STORAGE
Old Aug 1, 2021 | 08:52 AM
MattOzzz's Avatar
MattOzzz
LONG TERM STORAGE
I have a 2019 F250 Lariat Diesel. I'm going to be storing it away from home for a few months this winter. I will not have access to it during this time.
I have had other vehicles that stated in the OM to pull a certain fuse in lieu of disconnecting the batteries for long term storage but I can't find anything like that in my OM. Only this,
  • If storing your vehicle for more than 30 days without recharging the battery, we recommend that you disconnect the battery cables to maintain battery charge for quick starting.
Does anyone have a hack for this? (There will be no power available)
Thanks,
matt
Old Aug 1, 2021 | 09:08 AM
C12H24's Avatar
C12H24
If it's stored outside, you could use a solar-powered charger and just keep the batteries connected. Honestly, if the batteries are in good nick, then I would just leave it be without any intervention. Thirty days is nothing. They sit on the dealer's lot for longer than that. The modules will put the truck in hibernation so there's not going to be any significant drain.
Old Aug 1, 2021 | 09:23 AM
shawnee1's Avatar
shawnee1
OP stated the truck would be stored for a few months. Vehicles may be on the dealer's lot for longer than 30 days but they typically don't sit in one place for more than 30 days. They are started and moved around the lot either due to test drives or just changing the position of how vehicles are displayed on the lot.
To the OP, disconnecting the battery cable(s) seems like a simple, foolproof method. Pulling a fuse may be easier but if a fuse would do the job, I would think the owners manual would recommend it.
Old Aug 1, 2021 | 10:23 AM
Fordalordian's Avatar
Fordalordian
Following.
Old Aug 1, 2021 | 11:14 AM
kdin1's Avatar
kdin1
Thanks,
matt
I would put dryer sheets in the cab and on top of the battery will keep anyone from enjoying the wires.
Old Aug 1, 2021 | 01:35 PM
Rwhjr's Avatar
Rwhjr
Use Ford Pass app to remote start a few times?
Would that work?
Old Aug 1, 2021 | 02:01 PM
powerboatr's Avatar
powerboatr
Thanks,
matt
is it going to be inside a garage or out in the weather?
inside or out air tires to max, if parking on asphalt, use plastic blocks or wood to park on to prevent sinking
dryer sheets inside and in engine bay (remember where you put them) Irish spring soap bits in a small lid also works great at driving flies and mice away, but spiders like it? capsacian cream also works great at driving mice away, apply a small amount to the wires, but remember to not touch your eyes if you touch wire looms later
moth ***** spread around on ground under and around truck
cover tires and coat with tire dressing (both sides)
disconnect batteries, easy to relearn and reset everything once hoked back up, then fully charge both batteries
top off fuel tank and add appropriate conditioner ( powerservice, hot shot, ford ,dealers choice)
clean inside and apply dressing to seats and dash . put in a window sun blocker and all windows if possible make sure no food or gum or trash is left inside
thats how my previous super duties sat for 6-9 months at a shot, in my garage
there is also a blurb in the OM that lists needed tasks
Old Aug 1, 2021 | 02:12 PM
Mlarv's Avatar
Mlarv
I would add a few other things to this list.
Inside or out side I stick steal wool into the exhaust pipe and cover with an old sock.
I use the same thing they use in boats to keep the humidity at bay Damp Rid
I place a sheet of paper on the drivers seat with a list of what I did to put it in storage then make sure I check off everything when I take it out.
I had been storing a 2013 Shelby that way until I got rid of it last year.
Old Aug 2, 2021 | 10:27 AM
HRTKD's Avatar
HRTKD
Even disconnected, lead acid batteries have a self discharge rate that, over a few months, will result in a battery that won't start a modern vehicle. Discharge rates of 4% per week to 1% per day are not unusual. A smart battery maintainer connected to the battery while still installed in the vehicle is a good solution.
My truck will sit for as long at 8 weeks in the winter with a CTEK MUS 4.3 connected to it. I've had no problems with that setup, but mine is in an unheated, but attached garage.
Old Aug 2, 2021 | 10:41 AM
CP Dubbs's Avatar
CP Dubbs
Only a few months?
Trickle charger on either battery, they are tied together. Battery Tender or NOCO.
Full tank of fuel doped with a biocide and stabilizer.
Park it.
Mine sets from Nov 1 until Apr 1 every year.
Fires right up.
I do change oil if even close so it does not have a lot of acids coating everything.
Old Aug 2, 2021 | 10:57 AM
cat-alac's Avatar
cat-alac
Battery tender it and leave it, or disconnect ground.
Old Aug 2, 2021 | 11:03 AM
GNR22's Avatar
GNR22
If the concern is the battery going dead from sitting in storage without access to electricity, just pull the battery out of the truck altogether and take it home, put it on a trickle charger in your own garage.
The suggestions above are very good.
Old Aug 3, 2021 | 09:11 AM
MattOzzz's Avatar
MattOzzz
Inside, NO POWER. I'll just disconnect the batteries and hope for the best. Some other good suggestions I'll use, too.
Thank you,
axelthrasher
Dec 1, 2020 01:48 PM
BPofMD
All Things Towing
30
Aug 3, 2016 09:45 AM
Bigboy99
Feb 24, 2014 09:51 AM
FordMan35
Aug 13, 2010 06:37 PM
pepito113
2004 - 2008 F150
Mar 25, 2009 06:34 PM
