New 66
Old Aug 5, 2021 | 02:12 PM
dubya TF's Avatar
dubya TF
Good deal getting it home! It may be the perfect chance to put disc brakes up front.
Old Aug 5, 2021 | 09:15 PM
Cheddar's Avatar
Cheddar
Just get the right lugs you'll be on the road ASAP, they're cheap, they don't need to be pressed in, hopefully they will not seat all the way in which would mean they will be properly tight and the idiotic wrong lugs (that guy needs a talkin to at least!) didn't broach out the holes. They should stick out far enough to thread a lug nut on, I flip the lug nut so the flat side bears the load and just tighten the nut and it will pull the lug into place. That's it, unless they are real loose I can't imagine needing to tack or god forbid really weld them, imagine the suck if you happen to break one off for whatever reason and you had to get it out…
I'm sure there are a million youtube videos on popping in a lug, or five or maybe twenty in your case, good luck!
K2thO
Aug 3, 2021 07:08 AM
RenoDa
16
Jul 8, 2019 12:12 AM
DXf-250
Sep 1, 2012 10:08 PM
cheddar89
Feb 16, 2012 10:02 PM
slickmainer
13
Dec 29, 2011 02:40 PM
