High Pressure Crossover Hose??
Old Oct 31, 2003 | 01:43 PM
HeatStroked's Avatar
HeatStroked
Question High Pressure Crossover Hose??
I have visited a few PSD sites and have seen information on
a high pressur cross over hose?
Product claims:
"This hose is used to bridge the two high pressure oil rails in the cylinder heads that feed the injectors. The installation of the HX kit will result in a more even delivery of fuel to the injectors. By evenly distributing oil pressure, the idle will typically smooth out due to the computer being able to read the oil pressure of both high pressure oil rails, and thereby balancing the pressure between both rails. This modification can calm down (quiet) rough idling Powerstrokes."
Has anybody installed this hose?
Any difference in performance or idle?
Worth buying?
Thanks for the input!
Old Oct 31, 2003 | 02:02 PM
Quadzilla's Avatar
Quadzilla
"Has anybody installed this hose? "
I've put it on mine.
"Any difference in performance or idle? "
It smoothed out the idle considerably, and made the truck run smoother overall.
"Worth buying? "
I'd say so. For what it costs, and how easy it is to install, I don't think you can go wrong. It won't make a huge difference in performance like a chip, but it's an enhancement that makes for a more driveable truck.
To me, it's gratifying when the wife tells me how much better the truck runs since I started doing mods. This is one of the things that improves the overall operation a little.
Old Oct 31, 2003 | 02:38 PM
HeatStroked
Quadzilla,
Well hell, I will be going out right away and buying me one of those things if it's gonna satisfy the wife! ........lololol
Thanks for the input Quad!.
Ordering one today!
Old Oct 31, 2003 | 06:46 PM
jharvey3's Avatar
jharvey3
Hey wakin' up the neighbors is part of the fun of these trucks but a happy wife means more goodies for the truck right
John
Old Oct 31, 2003 | 07:07 PM
F0rdF0rever's Avatar
F0rdF0rever
Heatstroked, where are you ordering the crossover kit from. Id like to look into it.
Old Oct 31, 2003 | 07:14 PM
HeatStroked
I have seen it at a few places.
Looks like the same crossover form every vendor.
Prices are within $5.00 of each other.
Old Oct 31, 2003 | 07:38 PM
F0rdF0rever
Thanks Heatstroked. Sounds like a good mod for cheap money. Im gonna order one. All these mods ive been doing, may be time to spend some money on a set of gauges...
Old Oct 31, 2003 | 10:10 PM
higa2000's Avatar
higa2000
I just installed one on mine last week. It made a remarkable difference in how smoother and quieter my truck runs. It's still louder than the 98+ powerstrokes but not as harsh as it once was. Like Quadzilla said, well worth it for what it costs and the installation is a snap. Good Luck!
Old Nov 1, 2003 | 09:42 PM
mueckster's Avatar
mueckster
I have the cross over line on my '01. I like the smoother idle. It also seems to have given my truck better acceleration and mileage. I am very pleased with the results for the money spent.
Old Nov 1, 2003 | 11:47 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It's not a bad mod by any means. Where I noticed it the most was with the 10K or the 5.6K resistor switched on. Helped to smooth out and quiet down the idle. Not much (if any) difference in power or economy.
Do make sure that you keep the plugs and a wrench in the truck, just in case.
Got mine from ITP
Old Nov 2, 2003 | 04:30 AM
Crumm's Avatar
Crumm
I would suggest getting one from Dale at TYMAR performance. His are made with a higher quality hose than most and are a little cheaper $ wise.
Old Nov 2, 2003 | 07:15 AM
F0rdF0rever
I have a question about the crossover. I took a look at my engine. The plugs the you are supposed to connected already have hoses coming out. They both go to a box in front and just below the fuel filter. Its a 95, is this right?
Old Nov 2, 2003 | 07:38 AM
Crumm's Avatar
Crumm
The "box" is the high pressure oil pump. You move the line on the drivers side head from #6 and attach it to #4. The crossover hose then goes from #6 to #5. Look at this Picture for plug number identification. This Picture shows the installation completed.
Old Nov 2, 2003 | 07:46 AM
F0rdF0rever
Ok, I understand. Thanks for pointing that out..
Old Nov 2, 2003 | 03:06 PM
cookie88's Avatar
cookie88
FTE Emeritus
That's a common misconception. Just because it's got a braided jacket does not mean it is higher quality.
