Sponsored by: Real Truck
Check Coolant Additive
Old Jul 26, 2021 | 01:07 PM
PatrickStapler's Avatar
PatrickStapler
2015 F250. Complete coolant flush and fill six months ago at dealership. This popped up this weekend. Fluid level is perfect. I assume this is something that probably should have been reset at the same time. I went through all the menus and didn’t see anything related. May be overlooking something.
Any way to clear this? Dealer only?
Old Jul 26, 2021 | 07:39 PM
cj45lc's Avatar
cj45lc
On my 2016 thee is a screen to reset that & the change oil warning with the button on the left of the steering wheel. I believe it's on the info screen
Old Jul 26, 2021 | 08:07 PM
PatrickStapler
I suppose I missed it then. I’ll look again.
Old Jul 27, 2021 | 06:58 AM
PatrickStapler
Found it under Settings Vehicle Maintenance. Same place as fuel filter reset.
Old Jul 27, 2021 | 09:45 AM
cj45lc's Avatar
cj45lc
Good deal, wish I could have been more specific but I knew it was there somewhere
Old Jul 27, 2021 | 10:02 AM
PatrickStapler
No worries. Appreciate the help.
Old Oct 11, 2021 | 09:21 AM
frysl's Avatar
frysl
I don’t think you got a complete answer. That light tells you to have the coolant additives (anti-corrosives) checked for effectiveness. The dealership will use a test strip to see if the chemical balance is good or if it needs to be corrected by adding more additives.
ajorn
6.7L Power Stroke Diesel
Nov 1, 2018 06:34 PM
Berriemaas
Sep 14, 2017 07:09 AM
Kurt32
Dec 10, 2014 01:53 PM
FORDSDOWNER
Apr 4, 2008 08:26 AM
PSDLOVER
Aug 29, 2003 08:50 AM
