Ruff stuff brake conversion kit
Old Jul 25, 2021 | 05:25 PM
0701ford's Avatar
0701ford
8th Gear
About a year ago we put a brake conversion kit on the old 97 it worked well for aviut 6 months then we started braking bolts that hold the caliper in on the passenger side. Put new bolts in and a few months later they would break again. (Grade 8 bolts and lock nuts) and so on a so forth. It feel completely off and we realized the caliper pins are bent fixed if then a month later the driver side flew off no warning or anything. Anyine else had these issues?
Old Jul 25, 2021 | 07:09 PM
Edgethis's Avatar
Edgethis
Is this for the rear to run disc's?
Are you torqueing them properly? Shouldn't be snapping grade 8 bolts often.
Old Jul 25, 2021 | 07:49 PM
0701ford's Avatar
0701ford
8th Gear
Yes rear brakes and the are torqued down.
Old Jul 25, 2021 | 09:07 PM
Edgethis's Avatar
Edgethis
Any pictures?
What is falling off? The caliper or the bracket on the axle housing? How thick are the bolts?
Red_ranger69
Jul 4, 2017 10:59 PM
AcesHigh
Jul 1, 2015 10:01 PM
DZL JIM
Jun 19, 2009 02:56 PM
tomcasino
Feb 19, 2008 02:36 AM
neon132679
Mar 16, 2006 05:10 PM
