I think it's likely that it will work, but it'll likely take some time to understand what's new/different with Sync 4. There are a few things from the 2017+/2020+ spreadsheets I plan to try.
It should work well. They have a spreadsheet going for the 2021 F150 that I have been using for my sons truck. I will be testing on my 2022 when it comes in for sure.
It will be nice to see many others trying it first since I love using it to disable all the nanny chimes and "features" I do not want.
ill be adding factory power running boards the day my truck comes home so I’m hoping it works I need access to ipc, it should work since it didn’t change.
I did some FORScan changes with my 2017 KR and a coworker's F150 a few years ago, but have not updated any license/access data since then. Subscribing to this thread so I might know when I'll need to update my access after the 2022 FORScan data is available.
Where are you getting them, and what is the cost? Do you know what the difference is between the factory power boards and AMP research is....?
The '22 I have on order has the stationary running boards with the black appearance package. I was not able to select power boards. I also missed out on a heated steering wheel.....
Slightly derailing question. I have never used Forscan on anything. I have a 2022 en route. Could using forscan do anything to possibly void the 36000/36 bumper to bumper warranty?
That question has been asked a lot, and the answer is no. FORScan only allows one to activate/deactivate selectable items already installed by Ford. Go review the FORScan thread(s) for more information.
OTOH, one can select items which may not be allowed by your state's motor vehicle code. Example: "Bambi mode" where the fog lights remain on when switching from low- to high-beams will (should) cause Virginia vehicle state inspectors to reject the vehicle during the annual safety inspection.
