No crank, no codes.
Old Jul 23, 2021 | 07:28 PM
Aarkie's Avatar
Aarkie
No crank, no codes.
I started the truck several times this morning with no problems, 2015, f350. Drove a hundred miles home and tried to start it a couple of hours later. All dash lights acted normal but it would not even turn over. I scanned for any codes and found no codes. You can find a long list of problems on the internet that fit this. I traced it down to the start relay. I had replaced the same model relay in a different circuit a few months back. I ordered 2 so I would have a spare. The coil on the bad relay was around 600 ohms and the new about 86 ohms. These new rigs have a hole lot more that can and will go wrong then the old ones. The relay is a 8t2t-14b192-aa and used in several circuits. They are cheap so you might want to get a spare for when it goes bad.
tcarr
Apr 20, 2023 10:53 AM
Motohead911
May 24, 2019 10:24 PM
blrman1962
Sep 23, 2016 02:28 PM
florida_1959
Apr 28, 2012 07:06 AM
91ford_ranger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jul 30, 2004 01:39 PM
