Part listing for different button configurations above screen
I have Traction Control on the left, Flasher/Hill Decent on the right.
If I had the 360 camera option would I have a third button or another split button with traction control?
https://www.villagefordparts.com/v-2...6-7l-v8-diesel
Currently I have a Naviks module for my Sync3. This allows me to hold the power button down for a few seconds, cycle through 3 camera inputs.
1) Front camera (any speed, any time)
2) Auxiliary Camera (any speed, any time)
3) OEM backup camera (limited to 7mph)
There is a dip switch on the module to allow camera 1 to come on automatically when switching from reverse to drive. This is great most of the time except when I need the normal rear delay function while hooking up my trailer. I soldered a lead wire to this dip switch so now I have a switch to turn this feature on/off without taking the unit apart.
Camera 2 is hooked up to my trailer’s backup camera. This is great - but again only when I’m using the trailer. I want to add additional cameras. I just purchased an OEM CHMSL camera online fairly cheap ($180 brand new from a dealer on ebay). I’ve been stalking eBay for a while to try and find one cheap as I didn’t want to pay the $400 TASCA wanted for it.
If I hook the CHMSL camera up with the OEM harness’ the internal communication system will lock it down after 7mph like the OEM backup camera - not ideal… so I got poking around.
After doing a lot of research and speaking with some electronics gurus on here, I believe I found a way to pipe in the CHMSL video feed outside of the internal communication and directly into my Naviks unit so I can now view the video at any speed by simply switching to the auxiliary camera port.
Now I’m down the rabbit hole of how do I wire this all up so I can switch between two yellow RCA video feeds going into only one available auxiliary input.
The simple solution is to add a RCA splitter and a switch that will transfer the 12v power between the two cameras so whatever camera has power will be the one that displays on the screen.
This is all well and good but I like the OEM look. I purchased a 4 channel, 12v relay board (leaves room for two more in the future if I want). I also purchased an Arduino Nano board and a small push tactile switch. I uploaded code to the nano board that will switch from Relay 1 to Relay 2, Relay 2 to Relay 3, etc each time the button is pressed.
So my final thought and the reason for this post is wondering if I bought the OEM camera button, could I replace the small tactile button on my bench test with the OEM camera button so when I press it, it will cycle through the cameras tied into the aux feed and look OEM at the same time.
I was really hoping they made a traction control / camera combo switch as I didn’t really want to shell out the extra money for the three button bezel.
Anyway, sorry for the long post but that’s what I’ve been up to. If I ever get it work I’ll try to share a write up for anyone that is interested.
This is one listed as being for an F-150.
That may be worth looking into as they aren’t that expensive.
Next time i’m bored I will move the camera button over to the left side. I need to decide on one of these modules to allow me to use the camera at “speed”. Seems like they all have their pros and cons. I really just want it to work like OEM but without the speed restrictions.
I like the front camera for nosing into tight spaces but always seems like I push the button before I’ve slows down quite enough to allow it. Then you have to wait for the warning to go away…
Does anyone have the part number for the lane keep assist / camera button? I would need this item as a doner take swap the diesel break button with the camera icon.
I’m assuming these are all momentary switches internally?
