Thinking about swapping 5-speed to AOD
Old Aug 9, 2000 | 11:49 PM
hotrodford_88's Avatar
hotrodford_88
I am thinking about swapping my 5 speed out and putting in an AOD. My left leg starts to get a little tired after driving in traffic around Houston, Texas!
Hopefully somebody had done this and can tell me what kind of nightmare I'm getting into.
1988 F-150
5.0 EFI (former 300 I-6)
Mazda M5OD 5-speed
Old Aug 10, 2000 | 07:21 AM
kaution's Avatar
kaution
I replaced a 5 speed with a C6 on a 88 F-150 4x4, just a few months ago. The problems you might have is:
1) running coolent lines from the radiator.
2) new fly wheel and starter
3) you probable will need to modify the mounting bracket for the transmission.
4) you will probable need drive shaft work done.
Some other words of wisdom are make sure you get the proper transmission for 4x4 or 2x4. B&M makes a nice truck shifter that mounts on the floor and is high enough for use in a full size truck. The reverse light switch is located by the transmission, you can run them up to the new shifter. You can use the wires from the switch at the clutch, which prevent you from starting the truck unless the clucth is in, to prvent the truck from starting in gear.
When installing the transmission make sure the torgue converter is in place and then put the transmission in (this is a pain in the neck) otherwise the cats will be in the way and the transmission will not go in. We learned this the hard way.
With my brother and myself we finished the job in a weekend (minus the drive shaft which were then being modified).
I hope this helps I can supply more specific information if needed.
Kaution
Old Aug 10, 2000 | 10:13 AM
rocky50's Avatar
rocky50
>in an AOD. My left
>leg starts to get a
I know what you mean about Houston traffic.
That's my feeling.
Hotrod, I'm having to do the same, but to replace a 3sp. C5 that came with the 6. On the Houston freeways if you're not doin 80mph, well you know...
I plan on using a 83 TownCar AOD, I've bought the TV cable, ($100) and plan on using a TransGo kit.
Moe
85 f150 orig.300/6 now 95 302HO crate w/ AFB
Houston
Old Aug 10, 2000 | 11:11 AM
StrangeRanger's Avatar
StrangeRanger
You might not be real happy with a stock AOD. Go to www.baumannengineering.com and browse around their history of the Ford automatic stuff for some ideas and info. The guru on building AODs is www.artcarr.com. Huge increases in both reliability and performance.
Old Aug 10, 2000 | 04:35 PM
deleontow's Avatar
deleontow
danwtx
New Member Introductions
Nov 11, 2014 10:28 AM
Broncoslocos
Oct 12, 2008 11:05 PM
jdbanks
Texas Chapter
May 18, 2005 09:32 AM
ktlspop
Feb 12, 2005 06:45 PM
Warren2004f150
2004 - 2008 F150
Sep 8, 2004 07:46 AM
