Hello all! I have a sweet running 351W/FMX in a '77 Cougar that I am considering swapping into my '89 F150 that currently has the 302/AOD. Staying with the AOD. What mechanical issues will I have, like the flywheel and starter? Any balance issues? Going with the carb swap, so no EFI. Thanks ahead of time.
Silly question -- what does your Cougar look like? I have two '73 Q-code (351C-4Vs), but I also like the '77-79s! I have a 395W stroker that is looking for a home...
In a mid '80's crown vic was the only time the 351/AOD combo appeared from the factory, it's 28oz imbalance with a 164 tooth ring gear and AOD specific offset.
