5 star tune / voltage
Old Jul 19, 2021 | 07:07 AM
Terror Dome's Avatar
Terror Dome
First off I’ve got a 2017 F350 cclb 6.2l.
I’ve noticed recently that my truck seems like when it cranks that it’s starting to get slow like maybe the battery is getting weak. I watched the voltage on my programmer as I driving and it was saying 14.1 - 14.2 so I put my battery charger on it and this morning it was better for sure.
I was curious if something in the tune would draw more from the battery or alternator cause the battery to get drained more? My thought was to get a new alternator and also get a 240 amp rather than the 220 amp that’s on my truck now.
Any info on this would be great. Thanks
Old Jul 19, 2021 | 07:17 AM
Smindustries's Avatar
Smindustries
Your alternator is working. Your battery isn't. Start there.
Old Jul 19, 2021 | 07:22 AM
B-ManFX4's Avatar
B-ManFX4
The tune should not alter anything with the truck's charging system. Changing the alternator is an expense that will have little if any return. 4 years on the battery - I'd start with replacing that.
Old Jul 20, 2021 | 05:43 AM
Terror Dome
Thanks for the replies. I’ll grab a battery at Napa.
Old Jul 20, 2021 | 06:53 AM
Poncho450's Avatar
Poncho450
Charge the battery and then load test. Go from there.
Old Jul 20, 2021 | 09:55 AM
HRTKD's Avatar
HRTKD
On my prior truck, slower starts were my clue that the battery was on its way out. A volt meter on the battery at various times (after sitting for a while, while running, etc) is good data to make a decision from. If you have any aftermarket electronics installed, that may be a good place to start.
A well rested lead acid battery will have a voltage slightly higher than 12.6.
RFink
Aug 9, 2016 04:26 PM
FlexYJeeper
Jul 26, 2016 01:46 AM
tinman565
Jul 26, 2011 06:35 PM
Benaghetto
1983 - 2012 Ranger & B-Series
Feb 15, 2007 04:04 PM
Bloss Man
Dec 16, 2003 01:45 AM
