Connector source
Old Jul 18, 2021 | 03:51 AM
MrGGermany's Avatar
MrGGermany
Connector source
Anybody know if these original connectors are reproduced?
Fan speed selector switch connector
Preferably with this pigtail and connector already attached
Old Jul 18, 2021 | 08:34 AM
mikeo0o0o0's Avatar
mikeo0o0o0
From personal experience this is a relatively common problem. The wires in that harness, in my opinion, were undersized for the amperage draw required. I've seen three that were damaged exactly as you described.
The last one I fixed by finding a decent plug in the junkyard, I know, not an option for you, and reuilding the harness.
I basically just used the plastic shells and used new terminals with heavier gauge wire. This solved my problem.
Old Jul 19, 2021 | 02:42 AM
Dentside Dave's Avatar
Dentside Dave
Is that from the Blower switch? Mine was melted in the same way though the blower itself is in good shape and does not draw too much current. I used insulated single connectors and removed the melted plastic connector.
Old Jul 19, 2021 | 03:09 AM
MrGGermany's Avatar
MrGGermany
Yeah, I had this idea as well....just thought I'd see if the actual connector was reproduced first. I guess, I'll be buying some of these spade connectors.
Old Jul 19, 2021 | 03:15 AM
MrGGermany's Avatar
MrGGermany
The one wire that is frayed/got hot looks pretty heavy. It probably frayed and came into contact with some metal and then melted the connector. PO just taped it up and called it good. I was actually looking into why my fan only blew on low when I found the melted connector. I cleaned up the switch internally and hit the connector with some contact spray.....my fan now blows on all speeds, so THAT'S something.
Old Jul 19, 2021 | 08:49 AM
NorEaster603's Avatar
NorEaster603
You could use a generic connector like a Weatherpack.
https://www.wiringdepot.com/store/c/...onnectors.aspx
if you are trying to keep things original I can’t comment on a source though.
Old Jul 20, 2021 | 02:40 AM
MrGGermany's Avatar
MrGGermany
I'm going for as original as possible within the constraints of my budget! I actually have some of those or something similar, but they won't hook up to the back of my fan speed selector switch. I'll just get some insulated spade connectors. Thanks for the idea though.
Jared H
Sep 29, 2020 10:03 AM
calvinhg
Jul 5, 2020 10:10 PM
sere0501
Feb 21, 2016 10:39 PM
PRIMERED79 SHORT BED
Aug 9, 2012 09:57 PM
Schtoke
Aug 26, 2008 06:34 PM
