1970 F100
Old Jul 15, 2021 | 09:28 PM
JCroke's Avatar
JCroke
1970 F100
I am new here. I am trying to find a diagram for the grease zerks on my 1970 F100. Any one have any info or leads that may help? Thanks, John
Old Aug 9, 2023 | 04:19 PM
Inxs F100's Avatar
Inxs F100
4wd Low
Update on blinker. Cleaned the rust on the right front, no help. when checking to see if the rust removal worked, I noticed that the blinker indicators worked by applying pressure to the switch. So I pulled the wheel and checked the blinker switch. I was finding that the PO had made repairs by seeing electrical tape on the wires. Commence to order a new switch. I also noticed that the steering column had play. I pulled the column out and replaced the bearings and sleeves. Put the truck back together and the blinkers work great. Thanks for all the input.
Old Aug 9, 2023 | 04:33 PM
RTT's Avatar
RTT
Great question on the zerk , I want 2 know the answer also !!!
Your lucky u did not have to replace the switch.......
Old Aug 10, 2023 | 05:22 AM
FuzzFace2's Avatar
FuzzFace2
WOW think someone posted to the wrong thread
The Zerk fitting cant be that hard to find.
1 at each tie rod end
1 at the upper and lower kingpins on each side - I like to grease them with no load on the wheels.
May have then on the drive shaft Ujoints - dont know how many joints your truck may have and it may also have a front drive shaft?
Maybe shift linkage for 4x4?
If manual trans the clutch linkage, maybe the cross shaft?
Cant think of any other ATM
Dave ----
Knotwall
Nov 13, 2019 05:15 PM
74F100OKC
Apr 18, 2018 09:43 AM
lilsmokey
Apr 14, 2016 08:52 PM
2coolcars
Jan 8, 2008 04:16 PM
slntnddly
Oct 26, 2003 02:06 PM
