2002 Ranger 4.0 SOHC Knock Sensor Wire removal
In the middle of Water Pump and Complete Thermostat Housing replacement (both are off the truck now)
The wire that leads underneath the upper intake to the Knock sensor is damaged (one wire is broke and far enough back i cannot repair it)
It looks like it is attached to the sensor with a single nut on top? Is this correct? I imagine I can reach with a long wrench and remove nut , pull the wiring connector off, repair it and re-connect it.
I am going to get a better flashlight and look closer. I see Auto Parts store has the whole harness from sensor to plug in on side of upper intake passenger side. (two wires)
The following users liked this post:
Yep, looks like a critter made a meal of that KnockSensor cable; mice love to nest in that cave under the manifold.
Consider a new left OilPressurized TimingTensioner, if it's got over 75kMiles, while ThermoStatHousing is conveniently out of the way?
Hope a new Aluminum ThermoStatHousing is replacing old junk plastic one?
More info at
https://2001fordexplorersporttrac.fa...mingTensioners
https://2001fordexplorersporttrac.fa...ant_ThermoStat
More info at
chadgt
1983 - 2012 Ranger & B-Series
11-28-2018 10:41 AM
Ridenred333
01-05-2014 07:45 PM
grosseile88
09-10-2011 10:37 AM
rgillies1986
06-25-2004 01:56 PM
