Fumoto oil pan drain valve
they make tools for the spring clamps.
https://www.matcotools.com/catalog/p...-CLAMP-PLIERS/
Received 3,848 Likes
on
nothing like a good set of tools. i really like this hazet set. the number of clips being shot across the shop has been greatly reduced lol
https://www.kctool.com/hazet-1845-8-circlip-pliers-set/
forgot to link the stahlbus I am using. I think it's a better product than the fumoto, which I've used before. no experience with the ez-drain.
https://smile.amazon.com/Stahlbus-Dr.../dp/B01AMXAVX0
I agree, and I previously used the Fumoto on every vehicle I owned! They even make a "race cap" which you can safety wire (as I do on my race cars). The works well, just insert the drain and stick the hose in your drain pan. No mess (I realize the same thing can be accomplished with the Fumoto).
Another option to consider
https://www.nospillsystems.com/design-spec.cfm
Zero issues with the compact model on my 6.7. Just screw up the 90 degree hose attachment and point the other end into a 5 gallon bucket. No clips or ends that protrude. Clean design imo. Buy what you like - nice to have many options to choose from ( EZ, Fumoto, no spill, etc) .
It"s personal preference. I don't care about speed but I do care about flow control because I drain the oil into the gallon oil jugs from the previous oil change. Also I can pull a sample without making a mess. It takes a little bit longer but it doesn't bother me a bit.
The standard and compact instructions:
https://www.nospillsystems.com/uploa...ns_STD__CD.pdf
The Speed click design instructions:
https://www.nospillsystems.com/uploa...uctions_SC.pdf
For anyone interested, here is the parts finder page.
https://www.nospillsystems.com/store/part-finder.cfm
There's also this one I found on Amazon.
#28
#29
2 questions:
1. Can anyone with a 22 SD confirm that the F106SX does indeed fit their truck?
2. Has anyone used the tubing? I thought about getting the one with the long nipple but liked that I can rotate the F106SX to whichever exact orientation I want it, and it comes with the short nipple.
#30
Received 6,975 Likes
on
The tubing that came with my valve had three plastic fittings that snap onto the valve. One goes straight out, one goes 90°, and I can't remember what the other one does.
I've been using the straight one, but I'm going to start using the 90° fitting. This will allow me to trim the tubing so that it extends just an inch or two into the jugs that I empty the oil into. A tube that is too long just makes a mess when I pull it out of the jug.
The following users liked this post:
