Media System Problems
Old Jul 13, 2021 | 09:54 AM
MWB777's Avatar
MWB777
My 2020 F250 Lariat has less than 10k on it and the media system is already acting up. Media button doesn’t work to go from AM to FM to XM to phone, etc. It locks up on a station and the selection **** won’t change it. I’ve tried to set the station selection buttons while in separate modes and the buttons don’t seem to have any connection to the mode your in. Very frustrating. Even more frustrating is that it is intermittent, and, of course when I brought it into the dealership this morning to show the rep, it seemed to work. I’ve also had issues with startup and no reverse camera for a minute or so. Anyone else had this issue - and if so, what was the fix?
Old Jul 13, 2021 | 09:57 AM
ford390gashog's Avatar
ford390gashog
The issues can normally be traced to a bad APIM. Have you done a master reset of the system?
Old Jul 13, 2021 | 09:59 AM
MWB777's Avatar
MWB777
Thanks - trying to get them to do that at the dealership. What all does that re-set?
Old Jul 13, 2021 | 10:06 AM
MWB777's Avatar
MWB777
OK - forgive my ignorance. Looked up resetting the APIM and it’s something I should have done. I’m assuming the dealer will do that - if not I will.
Old Jul 13, 2021 | 10:13 AM
ford390gashog
The master reset can easily be done by you. It's in the system settings.
Old Jul 13, 2021 | 10:11 PM
MWB777's Avatar
MWB777
FYI - mechanic had to do the APIM reset, but also had to download an update to get it working right. Now my FordPass won’t sync - but not worried about that. But, at least the system now seems to work. Hope so - have a 1k trip ahead. Thanks all for the collective wisdom in this forum!
Old Jul 16, 2021 | 02:36 PM
MWB777's Avatar
MWB777
Update - Problems Continues
After the APIM reset and update, the problem continues. I’ve narrowed some symptoms down to this. I usually leave the radio on to SiriusXM when I shut the ignition off. It usually comes back on when starting up and media button rotates modes from XM through FM - then everything locks there. Selector buttons don’t work. Media button won’t work. But the FM station stays on. Go figure! Have appt again Monday. Any thoughts to pass on to the frustrated mechanic?
Old Jul 16, 2021 | 06:44 PM
Tom N OH's Avatar
Tom N OH
No guarantees but, try this. When starting the truck, put the key in, turn key to “On”, wait until the radio starts to play, then start the truck. I have to do this with my 2017. If I just jump in &crank it right away, it will revert back to AM every time. YMMV
Old Jul 16, 2021 | 06:46 PM
99FORD EXPY.'s Avatar
99FORD EXPY.
MY 2021 IS DOING THE SAME THING!!! The SiriusXm station goes dead but AM and FM work just fine,sometimes everything locks but just today on my way home the Sirius stations went dead but all other stations and buttons worked. Guess I need to make an appointment as well. Let us know how it goes with the dealer.
Old Jul 16, 2021 | 08:20 PM
GABAR's Avatar
GABAR
An APIM replacement might be the next step or perhaps these issues will be resolved via the next SYNC update.
Old Jul 16, 2021 | 09:10 PM
MWB777's Avatar
MWB777
99FORD EXPY - thanks for sharing that. At least I know I’m not alone - meaning Ford will probably have to come up with a solution. And I’m thinking you might be right GABAR. The dealer intimated they might have to order parts. I can’t imagine how one gets to that media system in the dashboard.
Old Jul 17, 2021 | 04:08 AM
99FORD EXPY.
where is the APIM located, is it behind the radio ? I believe I had noticed a separate box in that cavity that plugged into the radio
Old Jul 17, 2021 | 08:22 AM
trkester's Avatar
trkester
My 2021 F350 XLT is doing the exact same thing except my Sirius will work all day long until I turn the vehicle off and then back on a little while later (within a minute or two) . Am/fm good, sirius nothing. I have to leave the truck off for a longer period of time for it to come back. And no amount of time will bring it back without shutting down. Drove for 3 hours coming home listening to FM cause of no sirius. The other thing is, this is a more recent issue. (month or two) It has not happened the entire time I've had it (December).
Old Jul 17, 2021 | 08:50 AM
MWB777's Avatar
MWB777
If it wasn’t for the fact that the media button doesn’t work, I would wonder if it is a SiriusXM issue.
Old Jul 17, 2021 | 10:13 AM
trkester's Avatar
trkester
That and my 2019 Edge doesn't have the issue. I would think we would have the issue on the Edge as well if it was a Sirius problem. Guess a trip to the dealer is needed. 🙄 Good thing is it's super reproducible which is always a plus.
