Installing WeBoost…power inverter for power source?
I hear ya. There's plenty of room behind the seat back there as well.
The following users liked this post:
The inverter’s AC waveform is a rather nasty modified square wave, and not a nice clean sine wave. I’d try a temporary hookup to verify satisfactory operation before committing to the inverter as a power source.
We have the WeBoost RV Drive Reach for our camper. I bough the option DC power supply so that I can run it from 12 Vdc.
HTH,
Jim / crewzer
HTH,
Jim / crewzer
HTH,
Jim / crewzer
HTH,
Jim / crewzer
This HAM radio sits behind the PASSENGER seat. Granted the antenna is outside the truck, but if there was any RF off the inverter, due to it's proximity to it, the inverter would overload the front end of my radio. As it is now, I don't pick up any noise from the inverter.
Received 6,970 Likes
on
What about putting it in the bottom of the center console? There is a 12v plug there, but it will stay on for a while after the key is off. If you want it under the back seat, 12v switched or constant power isn't that far away in the passenger kick panel. That's where I get power for my dash cam. It's a clean install with the cords running under the door scuff plates (not sure what to call them, need more coffee).
My WeBoost device gets really hot. I don't have it in my F-350, it's in my RV trailer. I have it mounted vertically in the open so it can get some airflow. I started off using the 120v power supply and that worked fine connected to my MSW inverter. To make the wiring easier/shorter, I switched to the 12v power supply.
