torque convertor?
Old Oct 30, 2003 | 11:12 PM
slntnddly's Avatar
slntnddly
Question torque convertor?
At the spot where the starter goes into the tranny, are the teeth inside on the torque convertor or the flywheel? If on convertor, where could i find one and how do i know what tranny i have to match the convertor up.
1975 f100
302 w/ auto.
Old Oct 30, 2003 | 11:40 PM
79 250 lariat 4x4's Avatar
79 250 lariat 4x4
it's the ring gear, or flywheel..it might improve the engines performance alot if u had it turned at a machine shop, I've heard it makes a huge difference
look up the VIN# and have ur tranny and axle codes as well. it will tell you what tranny it has
try here for VIN# ID
http://www.medicine.wisc.edu/~mrm/bronco/ftvin.cgi
Old Oct 30, 2003 | 11:43 PM
Torque1st's Avatar
Torque1st
Posting Legend
Actually if you have an automatic it is called the flex plate.
Old Oct 30, 2003 | 11:47 PM
79 250 lariat 4x4
flex plate eh? shows what i know about autos.. i wish my truck was 4 spd..
Old Oct 31, 2003 | 12:23 AM
tetraruby300's Avatar
tetraruby300
..and the flex plate hasn't much meat to remove.
Old Oct 31, 2003 | 02:49 PM
slntnddly's Avatar
slntnddly
ok well my problem is this.....i removed my starter to have it tested and i noticed some of the teeth were worn on it. i then looked at the tranny teeth and noticed wear on it also. all i have to do is replace the flex plate?
Old Oct 31, 2003 | 05:00 PM
79 250 lariat 4x4
just get a heavy duty gear for your starter that'll save you some money and you won't have to replace the whole flex plate for a little while longer
Old Oct 31, 2003 | 07:11 PM
Torque1st's Avatar
Torque1st
Posting Legend
There is usually wear on the ring gear at 4 points where the engine comes to rest with a V-8. As long as you have at least 50% of the teeth at those points left I would not replace the ring gear.
Old Nov 1, 2003 | 11:02 AM
bushman's Avatar
bushman
If you do go to replace just the flexplate. Get yourself some really long bell housing bolts. Remove two of the tranny bolts and put those in. then get your tranny jack all set up and remove the rest. Then you just roll the assembly back just far enough to change your flexplate. when your done the tranny is rolled back foreward and the long bolts keep your alighnment so the tranny goes right on
