starting ?s
Old Oct 28, 2003 | 04:26 PM
lariat99's Avatar
lariat99
starting ?s
I browse a lot here but this is my first post. I tried finding some answers but i haven't found anything yet. I am restoring a 78 f150 with a 351m. i pulled it rebuilt it and have it back in. Everything is in and when i try to start I just get a click from the selenoid on the fender. It has a new battery and i had the old starter tested. it was drawing a lot so I got a new one. same click. do i need a selenoid too? thanks for your help.
Old Oct 28, 2003 | 04:32 PM
luckild's Avatar
luckild
Do you have a way to check the solenoid? Also, you can by-pass it with a jumper cable. Battery to starter terminal and it should spin.
Old Oct 28, 2003 | 04:39 PM
grapegravy's Avatar
grapegravy
Exactly, jump the solenoid main posts. If the motor starts, replace the solenoid.
Old Oct 29, 2003 | 05:50 AM
macguyver's Avatar
macguyver
Also, make sure you have a good connection between your ground cable and the block. Scrape off that nice new paint and use a star washer between the cable and the block.
Just a thought.
Old Oct 29, 2003 | 08:23 AM
armyguy's Avatar
armyguy
HMMM lets walk through this,If your getting a click then we know your getting power to the selenoid, and the selenoid is activated through the ignitiopn swicth so that`s good, the only thing left is the ground, some selenoids have two small studs "external ground" some had one small stud for the ignition switch wire and grounded internally, make sure you have a good ground..you say it`s a new battery, it`s a long shot but I`d try another battery or jump it with another vehicle just to make sure "you never know"
Congrads on the rebuild!!!!!!!!!!!!!!
Old Oct 29, 2003 | 09:18 AM
beartracks's Avatar
beartracks
I hate to mention this but are you sure the engine will turn over freely? Id put a breaker bar on the balancer nut and make sure it's not too tight.
Old Oct 29, 2003 | 11:35 AM
grapegravy's Avatar
grapegravy
Great point, Armyguy, I forgot about the internally grounded ones. If the mounting bracket isn't getting a solid connection with the wheel well then you would also have this lack of power problem. Is yours a two post or one, Lariat?
Old Oct 30, 2003 | 11:09 PM
plowpusher's Avatar
plowpusher
take a test light put it on the starter side of the solinoid hit key does it light no replace solinoid yes check the groud cable take a jumper cable go right to the starter from the bat try that if no go put a cable from the starter pos connection then touch the battery positive if that works that would mean a bad cable to the starter
Old Nov 1, 2003 | 01:26 PM
lariat99's Avatar
lariat99
the ground was bad and i replaced the cables
works like brand new. my timing is off a little but it runs thanks
Old Nov 1, 2003 | 03:28 PM
Torque1st's Avatar
Torque1st
Posting Legend
Thanks for telling us how it worked out!
