Door lock fuse help
Old Jul 10, 2021 | 07:27 PM
Icculus's Avatar
Icculus
Door lock fuse help
Hey y’all. Recently put in 2011 door panels and rewired everything in my 2002. Made sure all switches worked in my driver side master control and they did.
got it all together and had blown the master 102 fuse when soldering wires together.
replaced the fuse and now all sore windows work great.
however power door locks are now not working. These work off the same fuse.
is it likely I blew a actuator? I checked the pink wire going to the switch which is alway power and there is no power there. I do t even hear the locks trying to work.
any help would be great.
Old Jul 11, 2021 | 06:23 AM
Listor's Avatar
Listor
i'd have to say you either missed something or you blew an actuator, but certainly not all 4
Old Jul 11, 2021 | 08:54 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I am not familiar with the power door locks wiring scheme, but what about the possibility of the driver door being a master switch that the others run through or off of? A faulty switch or circuit here could remove all power and actuation from the other doors as well. Some power window switches and circuits work this way.
Also, sometimes the trigger leg of a circuit is the ground, not the positive. It is good that you have verified power, but what about ground verification when the switch is making/breaking contact?
I can pull the wiring diagram for the door locks if needed, just let me know.
Old Jul 11, 2021 | 11:59 AM
Icculus's Avatar
Icculus
I’ll double check the grounds.
Old Jul 11, 2021 | 08:53 PM
Icculus's Avatar
Icculus
fixed. thanks yall
Old Jul 11, 2021 | 09:19 PM
Sous's Avatar
Sous
FTE Emeritus
Originally Posted by Icculus
fixed. thanks yall
@Icculus , if you have a spare moment, we would love to hear how you fixed the issue.
Great news on the fix!
Swimholm
34
Jan 24, 2020 08:55 AM
wardracing
Sep 4, 2018 11:06 AM
krewmaxxed
Sep 21, 2014 09:24 PM
folsomf250
1997 - 2003 F150
Aug 19, 2004 01:53 AM
