E4OD flush
Old Jul 19, 2021 | 11:28 PM
AuroraGirl's Avatar
AuroraGirl
Originally Posted by GreenMountain95
Hey everybody got the trans all flushed. Made a fatal rookie mistake and would really appreciate your advice on a hopefully easy fix . I unscrewed the incorrect nut when taking off the trans return line, and broke the line. It is about an inch and a half shorter now and looks like I could pull it over and it would still work, but without the belled end in the threaded in peice the trans line would pop right out I think.
Is there an easy fix for this ? Like a repair coupling etc. I don't know much about what you can do with metal lines. Or do I need new trans return line?
I believe the help section in auto stores has the flared fitting you desire on a short straight piece so you could install and put a small section of hose between and if it’s short you just need clamps and wouldn’t need flares but a simple flats is not a bad idea to help lock any hose down.
Old Jul 20, 2021 | 12:05 AM
GreenMountain95's Avatar
GreenMountain95
Awesome idea ! Thanks Auroragirl that will work perfect. Very happy I won't have to replace whole line 😎👍
4.9brick
24
Mar 28, 2021 08:00 PM
CLR f-150
Sep 17, 2010 11:00 AM
driptorch970
Jun 4, 2004 02:07 AM
cbeaur
Nov 26, 2003 06:08 PM
