Tailgate step removal
Old Jul 10, 2021 | 01:53 PM
dads34's Avatar
dads34
I have a 2018 F250 that came with the tailgate step. Neither of us use it and we are getting up in our age where it is starting to get harder to close. I want to keep the tailgate because we have unique lettering. I understand how to remove the steps but cannot find how to fill in the void or if it is even possible
Old Jul 10, 2021 | 02:05 PM
Ding126's Avatar
Ding126
why not leave the step but not use it? Not sure the weight is a lot if you remove the step..What about finding a 2018 non step tail gate? Im sure many would trade you
Old Jul 10, 2021 | 02:11 PM
ATC_F350's Avatar
ATC_F350
The tailgate is heavy, have you looked at the tailgate assist kit for it? I don't know how much it helps, but it maybe easier than filling the void. The step tailgate adds 67 lbs to the rear.
On edit, it looks like most "assist kits" are to help with lowering. I thought I saw a thread that mentioned a kit to help lift it.
Old Jul 10, 2021 | 02:59 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
The actual step itself is not the heaviest part of the assembly, it's the internal tailgate reinforcement that adds the most weight to it. So, removing the step won't make the tailgate that much lighter.
Old Jul 10, 2021 | 03:02 PM
chadstickpoindexter's Avatar
chadstickpoindexter
Are you sure about this... I have had a tough time finding actual weights on things like this, and I tried because I was trying to add up each of the options I had. I never found anything "official" on this, but in a few random threads I happened to come across, the general consensus was that the rear tailgate only added 35 lbs. And if I am not mistaken, I think I also saw in another place (or maybe it was on YT) where it was stated that the tailgate with the step was only 97 lbs total. I'm not saying you are wrong, but if you can link to the 67 lb weight just for the tailgate step I'd love to see it. I will also add that when playing with the tailgate step on one of the trucks at my lot it didn't seem all that heavy at all when pulling the step out, or even the bar. They actually felt lighter than 35, but I assumed part of that weight was also for the assembly inside the tailgate that connected it. Either way, 67 lbs just for the step seems like way too much.
Old Jul 10, 2021 | 07:34 PM
ATC_F350's Avatar
ATC_F350
I don't know what the step tailgate actually weighs. But the 2019 Camper Loading Guide shows a weight adjustment of:
Tailgate w/Flexible Step Front (-13 MINUS) Rear (67 ADD)
Old Jul 10, 2021 | 08:10 PM
chadstickpoindexter
That’s interesting. Thanks!
Old Jul 12, 2021 | 01:30 PM
H4Racing's Avatar
H4Racing
I just replaced a conventional tailgate with one with a step and can confirm that it's at least 67#.....feels like more.
As stated above, removing just the step won't save that much weight....there is a lot of reinforcement in the center of the tailgate that adds most of the weight. And there is an assist built into the step tailgate to help with closing....the difference between the two isn't that much.
Old Jul 12, 2021 | 03:13 PM
dads34's Avatar
dads34
Mine does not have an assist of any kind for closing. Where can I find this?
Old Jul 12, 2021 | 03:30 PM
crewzer's Avatar
crewzer
Lightbulb
To me, this sounds like the optional tailgate step assembly adds 54 lbs. to the weight of the truck. The additional weight of the step assembly will use the back axle as a fulcrum and the truck chassis as a “see-saw board” to lift weight off the front axle and transfer it to the back axle. It’s a fairly simple statics problem.
I weighed our truck’s tailgate with the optional built-in step: 85 lbs. IIRC.
HTH,
Jimm/ crewzer
Old Jul 12, 2021 | 03:48 PM
crewzer's Avatar
crewzer
Lightbulb
Ours has a damper to help with opening, but I’m not aware of a closing assist feature from the factory.
HTH,
Jim / crewzer
Old Jul 12, 2021 | 07:25 PM
Thevol's Avatar
Thevol
As mentioned above the easiest thing to do is trade tailgates with someone without the step. Mine doesnt have the step in the tailgate but I did install an amp step that works great for me. I will say the aluminum tailgate is so light without the step it makes me a bit concerned about the integrity, not sure I would trust it with a bunch of weight on it but who knows...
Old Jul 14, 2021 | 07:05 AM
H4Racing's Avatar
H4Racing
There is a rod that runs from the hinge on the driver side. It's part 10 on the tailgate diagram:
https://www.bluespringsfordparts.com...ody--tail-gate
The tailgate hinge is keyed on the driver side, and you can only install the tailgate when it is at about a 75* angle. Lowering the tailgate puts tension on the rod, making the lift easier.....similar to a garage door spring I figure.
Old Jul 14, 2021 | 08:14 AM
99powerstrokedF250's Avatar
99powerstrokedF250
All of the above is correct. The step mechanism is fairly light - it is the reinforcement of the tailgate to accommodate the step without losing structural integrity that adds all the weight. Removing the step isn't going to help you much, and you would need to fabricate a bracket to hold whatever you put over the opening. I will throw it out there that removing the step MAY compromise the integrity of the tailgate - I don't know how it is configured inside or how much structural support the step mechanism is adding to the tailgate.
Your simplest solution is to change to a non-step tailgate and have your custom lettering added to it. However, you will lose the torsion assist (which, as described, is a lot like a garage door spring), which won't make the tailgate close much easier.
Old Jul 14, 2021 | 08:21 AM
BirchyBoy's Avatar
BirchyBoy
If your truck is Blue Jeans and you’re within 200 miles of Denver, I’ll come and swap tailgates
