Sponsored by: Real Truck
Front hub replacement
Old Jul 10, 2021 | 12:53 AM
rigid1's Avatar
rigid1
I had to replace the font hub on a 2003. When I remove the snap ring off of the axles stub it had a washer a hex shape spacer and then another washer against the hub. When I put the new one on There is not enough space to get that all in and the snap ring in the grove. It looks like I will have a hard time getting one washer on and still get the ring in the groove. What am I doing wrong?
Thank you
Old Jul 10, 2021 | 04:53 AM
crazyrt's Avatar
crazyrt
Trailering
Thank you
Pry the axle outward between the the flange and the axle tube.
Old Jul 10, 2021 | 09:36 AM
bajaphile's Avatar
bajaphile
Yep the axle shaft has some float inboard/outboard. Grab the end it with some large pliers and pull it out towards you. Some trucks have axle shafts with threaded hole so you can put in a bolt which is easier to grab.
245Smoke
Oct 1, 2018 11:02 AM
Boodrow379
Feb 23, 2013 12:18 AM
sotwclarinetguy
May 20, 2012 05:54 PM
leesflare
Jun 20, 2009 11:49 AM
cotote
Dec 7, 2008 06:23 PM
