Front seat issue?
Old Jul 7, 2021 | 11:38 PM
Frank79's Avatar
Frank79
Front seat issue?
Lately I’ve noticed that when I make a turn in the truck and my butt moves an inch or two on the seat I can feel something below the seat cushion moving as well. Almost feels like something is popping inside.
I do have heated seats, if that matters?
anyone else experience this?
Old Jul 8, 2021 | 07:37 AM
bertscw's Avatar
bertscw
I had the same thing.. a clicking and movement. I said something on the last service appointment and they said there was a service bulletin about that and fixed it. hasn't happened since.
Old Jul 8, 2021 | 09:09 AM
Frank79's Avatar
Frank79
yep, thats a better way to describe it, a clicking and movement. Do you know what the issue was?
Old Jul 8, 2021 | 09:42 AM
bertscw's Avatar
bertscw
They said it was something about a clip that was replaced. I honestly didn't dig into it as when I mentioned to the service rep I didn't expect them to fix and tell me it's normal.
Now I have to have them look at the steering wheel... I get a squeaking and very slight vibration coming from the column when I turn it.
Old Jul 8, 2021 | 09:52 AM
Frank79's Avatar
Frank79
It’s good that they fixed it. I’ll be taking my truck in for my first oil change here shortly and I’ll have them take a look at it.
One issue that I’m currently having is the steering wheel is not centered. It sits around the 11 o clock position, but the truck has no alignment issues it tracks perfectly straight.
when I had my 2019 truck I had the entire steering column replaced under warranty and when they put the new one on it was off-center.
The only way they could recenter the steering wheel was to do an entire alignment on the truck, which was on them.
since my truck only has about 4000 miles on it I know you get one free alignment within the first year or 12,000 miles, so I’m curious to know if they will try to say they will fix my steering wheel issue but it’s going to cost me the alignment Ford offers.
Old Jul 8, 2021 | 10:06 AM
Kellem's Avatar
Kellem
Hemorrhoids ??
Old Jul 8, 2021 | 11:34 AM
4wd6.7L's Avatar
4wd6.7L
It's actually an extremely simple adjustment on the drag link, it does not require an "entire alignment". Not so sure about that only 1 alignment in the first year/12k. If they didn't get it right the first time, I don't see why they wouldn't correct it free of charge.
As for the seat ussue, could it be this?
https://www.google.com/url?sa=t&source=web&rct=j&url=https://static.nhtsa.gov/odi/tsbs/2020/MC-10175895-0001.pdf&ved=2ahUKEwia8bzV9dPxAhXFHM0KHW13DRkQFjAA egQIAxAC&usg=AOvVaw0KiTT01Rv82RQ6HAIyBiHF
Old Jul 8, 2021 | 12:24 PM
Frank79's Avatar
Frank79
https://www.google.com/url?sa=t&sour...v82RQ6HAIyBiHF
the google link for the seat issue doesn’t go anywhere
Old Jul 8, 2021 | 12:27 PM
4wd6.7L's Avatar
4wd6.7L
Not sure why, it does on my end, should bring up a PDF.....anyway, you can find it yourself by searching TSB 20-2171.
Old Jul 8, 2021 | 12:52 PM
bertscw's Avatar
bertscw
You have to copy and paste...
I'll bet he's right, their description is spot on to what mine was doing.
Old Jul 9, 2021 | 05:56 AM
Smindustries's Avatar
Smindustries
There's too much in the URL for the above link to work. Here's the direct link to Ford's half-a**ed fix using heater hose and worm gear clamps:
https://static.nhtsa.gov/odi/tsbs/20...75895-0001.pdf
Old Jul 9, 2021 | 06:30 AM
Germanrazor's Avatar
Germanrazor
I bet some small town Ford mechanic at a dealer came up with this and proposed to HQ! That is usually how these things go. And if it saves them hundreds if not tens and tens of thousands of dollars, they run with it. Unfortunately, I have had to do the same thing in government work where they refuse to fund a fix and it is left to the worker bees to figure out a fix! Welcome to life!
Old Jul 9, 2021 | 06:45 AM
Lin19687's Avatar
Lin19687
Veteran: Navy
Thanks for the PDF !
I have saved it in my "things I can fix myself" . Wish they said why it sifts but meh, if I can fix it THAT easy, so be it
Old Jul 9, 2021 | 06:59 AM
bertscw's Avatar
bertscw
well, it appears that the repair that was done on my truck is the hose and clamp deal. It worked so why complain.
Old Jul 9, 2021 | 07:19 AM
03griz's Avatar
03griz
My 2019 does this and I figured the dealer would not be able to do anything.......I will fix it myself.
