View Poll Results: what is the most you have pulled with your truck?
10,000 or below
20.00%
10,001-15,000
30.59%
15,001-20,000
31.76%
20,001 or more
17.65%
Voters: 85. You may not vote on this poll
Max truck pull
Old Jul 7, 2021 | 08:10 AM
Grass Lake Ron's Avatar
Grass Lake Ron
Max truck pull
What is the most you have pulled with your truck?
Old Jul 7, 2021 | 08:12 AM
karlsdash's Avatar
karlsdash
Apparently we are the only 2 up this early... or at least at a computer.
Old Jul 7, 2021 | 08:35 AM
BowtieConvert's Avatar
BowtieConvert
I'll play. 40' gooseneck, 9700# empty + cargo. This is for my F-350. For GLR: I will say aside from the difference in ride quality, it's barely noticeable back there at cruising speeds. About 17-1800 RPM @ 75-76 MPH.
If the load is really heavy I'll use the F-550. Trailer GVWR is 25K & we've been pushing the limit a few times. The 550 is a 2019 Extended Cab &Chassis w/ 4.30 rear.
Old Jul 7, 2021 | 09:45 AM
Grass Lake Ron
It just means you have your setup done correctly. Saw a hotshotter this morning and instead of flat across, his truck was saggy in the center.
Old Jul 7, 2021 | 10:24 AM
GNR22's Avatar
GNR22
With my '21, about 10k is the most so far. With my '94, all of it.
Old Jul 7, 2021 | 11:04 AM
chadstickpoindexter's Avatar
chadstickpoindexter
My 22 is still on order, but I plan to pull my small camper with a 6000 lb GVWR. We may upgrade campers in the future now that our tow vehicle will be able to handle it, but not anytime soon.
Old Jul 7, 2021 | 12:35 PM
Grass Lake Ron
Is that a 460 in that 94?
Old Jul 7, 2021 | 12:37 PM
GNR22's Avatar
GNR22
Fuel injected 351w.
Old Jul 7, 2021 | 12:40 PM
Grass Lake Ron
Fuel injected 351w.
Really.... How wild or just mild?
Old Jul 7, 2021 | 12:44 PM
GNR22's Avatar
GNR22
Fairly wild. Here's the last pull from the 2019 season. https://imgur.com/XfBstD4
Stock bottom end with a really good top end.
Old Jul 7, 2021 | 01:01 PM
Grass Lake Ron
Very nice!!!
Old Jul 7, 2021 | 03:49 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
13,000# -ish with my current truck.
Hauled a F450 6.0PSD 4x4 C&C w/ a steel flatbed. Truck hit a phone pole & sheared off the drivers side knuckle, fender, and door. Winched it on my 10k trailer and towed it to a friends a county over who used it for parts for his 6.blow.
Old Jul 7, 2021 | 04:58 PM
CJONE's Avatar
CJONE
I was curious and ran my rig loaded and then after I unloaded across my buddies scales. 14' dump trailer with axles and LT truck tires set up by me. Had 17400lbs of crushed concrete on and missed my 30k gross by 20 pounds! Truck easily pulled it in 9th gear with no problem, just over 9mpg with 100+ miles. I may jump to a f350 dually but this truck has had no problems so far. Cj
Old Jul 7, 2021 | 07:23 PM
Desert Don's Avatar
Desert Don
I regularly pulled in excess fo 30,000 pounds with my old F 250, field to bin. No pics, sorry, it has been a long time back.
Loads of grain, loiads of coal, loads of firewood. Truck and trailer loaded to the nuts. I know, the weight police won’t approve.
Old Jul 7, 2021 | 08:17 PM
ATC_F350's Avatar
ATC_F350
I've pulled about 21.5k with my 25' full of hay and between 20-21k with my dump full of gravel.
