rear differntial - when to change
Old Oct 30, 2003 | 07:55 PM
bkaeding's Avatar
bkaeding
just had my truck serviced and was told rear diff needs to be changed. it was changed 5k miles ago. i told them this and they said it is awfully dirty. can this be possible?? i have been off road a few times but nothing major. thanks
Old Oct 31, 2003 | 07:11 AM
BigShelby's Avatar
BigShelby
At what rate gear oil turns brown or black I'm not sure. It is a natural occurance. Color therefore is not necessiarily a discriminator. If you changed it 5K ago then you should be good to go.
Old Oct 31, 2003 | 08:03 AM
bronco351's Avatar
bronco351
You should change your gear oil about every 15000-25000 miles!!
Old Oct 31, 2003 | 09:56 AM
jimandmandy's Avatar
jimandmandy
Unless you are towing, it is more like 100,000 miles. However, if it is submerged in water and the vent hose is missing or leaking, you need to change it. If you have a limited slip unit and used the additive, the oil will "look" dirty just because of that.
Jim
Old Oct 31, 2003 | 12:25 PM
LxMan1's Avatar
LxMan1
What vehicle are we even working on? The newer ones are synthetic and last a long time.
Jimmy
Old Oct 31, 2003 | 03:46 PM
bkaeding's Avatar
bkaeding
sorry 97 f150 xcab, 4.6 liter
i do tow a small popup camper, 1500 lbs, but not very often.
thanks
jpanz1881
2009 - 2014 F150
Apr 20, 2013 10:53 PM
xhotrodder
1983 - 2012 Ranger & B-Series
Apr 22, 2007 04:00 PM
jrfoy2
Feb 2, 2006 05:34 PM
Bruce_Bosley
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
May 2, 2001 07:06 PM
Brandon
Feb 3, 2000 09:02 AM
