Chipped block at timing cover
Old Jul 5, 2021 | 05:39 PM
Whitey5.0's Avatar
Whitey5.0
Any suggestions? I can’t tighten the bolt as is, so I’m afraid it will leak.
Old Jul 5, 2021 | 05:46 PM
SFaulken's Avatar
SFaulken
It might leak, it might not. I'd hit it with some RTV, and cross my fingers. Only real way to fix that properly, is to get it to a machine shop, and have it welded up, and machined/drilled/tapped. And I'm guessing that's a 5.0 Finding another block is probably cheaper.
Old Jul 5, 2021 | 07:51 PM
Edgethis's Avatar
Edgethis
+1 to what Faulken said. Small block ford's are cheap and easy to find.
Old Jul 6, 2021 | 08:09 AM
dremtofford's Avatar
dremtofford
j b weld. i once saw a 4 cyl boat motor with a big crack running down the side . it was fixed with jb weld.
Old Jul 6, 2021 | 08:11 AM
dremtofford
i once saw a 4 cylinder boat motor that had froze and broke and the guy fixed it with jb weld.
Old Jul 7, 2021 | 10:35 AM
JPIECHOC50's Avatar
JPIECHOC50
are you catching any threads there? if so, you might be ok sealing it up real good with rtv
Old Jul 7, 2021 | 11:43 AM
Whitey5.0's Avatar
Whitey5.0
No, the bolt spins freely.
Old Jul 7, 2021 | 01:30 PM
torq'ta 5 8's Avatar
torq'ta 5 8
Hmm...buddy bought a boat, motor same way, ran it 2yrs, before he sold it, clean the area very well, put JB Weld all on it and let cure, if the nut is made into stud, you could geta piece of stainless steel all thread, then JB Weld it, and have a nut to tighten up, if it happen to leak/weep.
Old Jul 7, 2021 | 03:48 PM
sandymane's Avatar
sandymane
I hit a rock that took a quarter size chunk of my Husqvarna Enduro bikes case out. That was in a test area Saturday and the race was Sunday. Since I was ten hours from home, I used JB weld for the hoped repair. It worked great and I finished the season with that bike and never had an issue with leaking. Proper preparation is everything with JB Weld.
gman6262
Jan 15, 2025 12:42 PM
Mark8man
Mar 10, 2020 02:03 AM
Jim40216
Jan 26, 2020 06:02 PM
johndeere46
Mar 6, 2013 06:00 PM
timmygyu
1978 - 1996 Big Bronco
Jun 16, 2011 12:45 AM
