Antifreeze Leak
I have a '90 bronco, 5.8 liter. I'm having a problem with an intermitant leak in my cooling system. As far as I can tell, it only leaks when it's been sitting for awhile. I'm including some pictures of the places where the fluid is accumulating:
Two of the pictures were taken in the dark with a flashlight; they are a bit wonky looking. The other was taken the next day, with rags in place to absorb the fluid. My best guess at this point is that it's leaking from the gasket between the water pump and the base plate, and/or between the base plate and the engine block.
I'm concerned that if I try to replace the gasket, the bolts that hold it in may be frozen, and I don't want to shear them off. I'm sure there are no leaking hoses from above that could be contributing to this problem.
Has anyone else had coolant accumulating in the same places? If so, did you determine the cause, and what steps did you take to stop the leak, if any?
Cheers,
Tim
Thanks for the tips; I'll be sure to PB the bolts good before I take it apart.
So the water pump mounts up against the timing cover, and the cover against the block? I guess that makes sense. The 'common leak' you mentioned though; is that between the timing cover and engine block, or the water pump and timing cover?
I guess another thing I'm wondering is if I can just limp by for a few more weeks; I'm right in the middle of moving, and I'm kind of under pressure to get that done. I don't think I want to take this project on until I'm done moving, but at the same time I don't want to neglect it and end up with a much bigger problem. As long as it's just an annoyance of mopping up a few drops of antifreeze, I can put up with it a little longer.
