E4od swap behind a 400.
Old Jul 4, 2021 | 11:15 PM
Elmer Lowe's Avatar
Elmer Lowe
I've been digging around on some of these forums for a e4od swap but I cant find much. I plan on putting a e4od in my 1978 f250. The np205 will likely bolt up to e40d with a clocking ring. But If anyone has completed the swap please send me some info!!!
Old Jul 5, 2021 | 09:14 AM
FuzzFace2's Avatar
FuzzFace2
I have not done this or looked into it but 1 of the biggest things is the motor to transmission bolt pattern, Do they make the E4OD in the 400 bolt pattern?
It sounds like you have the transfer case worked out.
And you will need to run an after market computer controller.
Dave ----
Old Jul 5, 2021 | 09:28 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I know a guy (Jeff is his name real nice guy, you might just PM him and ask) that did that swap, but he put a none turbo IDI diesel into his 4wd F250. Believe he has an E4OD and the controller he needed is like 500 bucks.
His thread on it: https://www.ford-trucks.com/forums/1...el-bandit.html
Maybe this one? https://www.usshift.com/usq4.shtml?g...QaAh1REALw_wcB
INFO: https://www.hgmelectronics.com/blog/...-transmission/
Old Jul 5, 2021 | 09:45 AM
DB429SCJ's Avatar
DB429SCJ
The E4OD was used with the 460.(same bolt pattern as the 400). Good E4OD tech stuff:https://www.becontrols.com/ourfaqs/e...1.htm#01033820
Old Jul 5, 2021 | 09:52 AM
FuzzFace2's Avatar
FuzzFace2
Diesel would have a different bell bolt pattern than the 400 no?
Well then its looking like the next step would be the converter to flex plate and its bolt pattern.
Will the 400 starter work with the flex plate if it needs to be changed out?
As they say someone has to be the first LOL
Dave ----
Old Jul 5, 2021 | 10:44 AM
77&79F250's Avatar
77&79F250
No idea on any of that, but pretty sure he had the C-6 the diesel came with, but as I understand it he wanted the E40D and it would not work right matter what the wiring set up was. Could not get it to shift right until a special trans shop hooked up their $$$$$ controller. Like 800 to 1000 bucks back then.
Old Jul 5, 2021 | 07:37 PM
Elmer Lowe's Avatar
Elmer Lowe
But don't places like us shift and others now have good stand alone controllers?
Old Jul 5, 2021 | 08:36 PM
65f100_352's Avatar
65f100_352
One of the cheaper options for controlling the e4od would be the TCU for an idi, as it was a completely mechanical motor.. another, if you don't mind doing your own tuning and wiring, is a microsquirt setup, can tune it to shift however you want to.. us shift makes the quick 4, and you can tune it, and it comes with a tune, but is more expensive.. IIRC, the quick 4 setup with harness is around $600, where the microsquirt is $300, and you have to build your own harness..
Old Jul 5, 2021 | 08:37 PM
Elmer Lowe's Avatar
Elmer Lowe
I'd like to go with the us shift plug and play would be the best for me
knords02
1978 - 1996 Big Bronco
May 12, 2020 11:39 PM
imabass
Jul 6, 2017 11:45 AM
plowboy1986
Large Truck
Apr 18, 2012 02:43 PM
colour
Mar 17, 2011 08:19 PM
CT
Nov 13, 2004 01:05 PM
