Can’t remove locking hubs on my excursion
Old Jul 4, 2021 | 10:38 PM
JakeLikesFords's Avatar
JakeLikesFords
Trailering
What title says. I’ve tried rubber mallets, sledge hammers, penetrating fluid, even screwdriver prying. Yes I took that snap ring out. I’ve even tried removing it both with it locked to the axle and unlocked. Any advice is appreciated.
Old Jul 6, 2021 | 07:16 PM
doorider600's Avatar
doorider600
the rubber o ring swells/sticks to the groves. I would suggest a cheap bicycle inner tube, cut a 2in wide strip the circumfrance of your hub. A large pair of channel locks and a friend. One of you squeezing the clamp over rubber "band" over the hub. The other of you using a 2 x 4 or similar to leverage between the tire and the pliers to "push" the hub "straight out. Other would be a bearing splitter if you can get the taper between the hub flange and the brake caliper hub.. It does not rotate.. just need to work it. unfortunately some "lubricants" make the swelling worse!
If you had some compressed inert gas that would get the hub really cold, the seal should shrink and make removal easier...
Old Jul 7, 2021 | 11:14 AM
96firephoenix's Avatar
96firephoenix
I had one that was stuck on really badly. I soaked the crap out of it with penetrating oil and tapped it with a hammer over and over and over.
I assume you're taking it off to replace it, right? if so, the pot-metal of the locking hub is weaker than the steel of the axle.
kissfan79
Feb 11, 2014 01:50 PM
Loadre
Nov 3, 2013 05:47 PM
78fordranger
May 6, 2012 08:12 PM
mach2race
Jun 13, 2006 05:18 PM
