5.4 3V Going Lean & Stalling
I have Forscan so I can monitor engine data live. Here are my observations:
-The Long term fuel trim is pretty high. At idle it's around 10% but running the engine at 2000rpm it will get up to about 25%
-Fuel pressure is steady between 38-40psi and the fuel pump duty cycle is about 20-25%
-VCT error % is very small and they appear to be working normally
-Timing advance is pretty steady and doesn't do anything weird when the O2 goes lean
-The PCM will detect misfires when the truck stalls
-There is a parameter "fuel injector fault" for each injector. All of those will show faulted when this happen. Not sure what that mean
Right before the truck dies the O2 sensors go full lean, the short term fuel trim % starts going up and the truck stalls. Before that the short term will be very steady and the O2 will be switching like normal.
Any ideas? I first thought fuel filter but the fuel pressure is steady throughout.
MAF reads 0.03V with the engine off. I watched a video by Forktechmakuloco where he talks about that being an issue. I swapped it with a known good MAF from another truck and it didn't seem to do anything. During running the MAF is pretty steady, no odd blips when the truck goes lean & stalls.
No vacuum leaks that I could find and typically that would show up at idle, not higher rpm/lower vacuum conditions?
Thank you!
Specs:
Key on, engine off 240-310 kPa (35-45 psi)
Engine running 193-310 kPa (28-45 psi)
I would be cleaning throttle body just in case ,try running it with snorkel off maybe plugged somehow . . After that I would be looking at plugged injectors ,contaminated fuel . Never hurts to test and clean injectors .If fuel filter not changed recently I would change it , look at fuel in a clear container . I don't know what work was being done last on the truck before this started .
Of course you are going to test cats , pressure test ,temp check ,maybe have someone feel volume at exhaust while you throttle up .
It must be dying because fuel ratio is so bad it can't fire. You do know 05's had bad series of injectors, I changed all of mine 100k ago . If they leak they can hydro lock and destroy engine . After 150k or so its a good idea to get new not reman injectors as they are high duty cycle and have to respond to milla sec pulse with commands to adjust fuel . But they are not cheap -nor do you want cheap . You can do a you tube test and clean station
Also the factory TB series was bad ,mine became intermittent at 60k . Mine kept going into limp mode . So yes an oem TB maybe a good thing , I tried reworking mine to no avail . Just make sure you get the updated version .
Also pulled off the Fuel pump module back behind the spare, had some light corrosion but the aluminum plate looked fine once I cleaned it off. Frame where it was mounted still had paint and not rust. Electrical connector looked brand new when I pulled it apart.
Also reset the PCM.
Watched the throttle commanded vs actual position and it seemed to track perfect.
After restart the Long Term Fuel Trims went nice and low, down below 5% at idle. Driving around the block the truck ran great, revved up to 4k rpm, long-term fuel trim stayed around 10-12%. Thought I had it licked but I went for a little bit longer drive and it started doing the same thing again. This time once it died while driving it wouldn't restart. Had to push it down the street back to my house. I'm starting to wonder if this is temperature related as yesterday I was running the truck in hot afternoon (100F) this morning it was a lot cooler.
When the truck dies the MAF reading is smooth and follows RPM so I don't think it's throttle related.
I see this thing doesn't have a fuel return, can vapor lock become an issue when the fuel rails get hot?
Check your crank sensor connection under engine ,any damage to that cable can shut it down . It is a frequent failure point and contains a shield that can ground out the signal . Monitor 12vdc pos on injectors with a test light to see if its string is dropping out. But I realize you don't have misfire indications either, you have fuel ratio problems .So we are back to lack of fuel or too much oxygen drawn in . ? Vapor lock at 100 degrees -I have my doubts . Is your tank full, you are not using e85 are you , can your fuel lines be getting near a very hot exhaust ? No reason for your system to be getting air bubbles when fuel pump in fuel tank under fuel . but just maybe your tank vent solenoid or carbon cannister is plugged or restricted . We need to pin it to just lack of fuel or not .
You have to let air in tank to get fuel out,this usually shows up if tank is hard to fill . Mud and insects have been known to cause this . See if your purge valve on fire wall is closed by blowing thru it ,it only opens on command .
You are correct this is a no return to tank fuel system , the fpdm controls everything with pcm oversight . The fuel rail pressure sensor is also vac assisted for acceleration I believe. The fpdm should be on standoffs to reduce electrolysis. If you have access to another try replacing it .
I'm reaching here ,interesting problem .
listed from top to bottom
-Long term fuel 1
-Long term fuel 2
-short term fuel 1
-short term fuel 2
-o2 voltage 1
-o2 voltage 2
-engine rpm
-fuel pressure.
about halfway thru you can see the o2s flatline and the short term skyrocket. This is when it dies. I’m either loosing fuel or all of the injectors are losing power to fire. Don’t think it’s an air issue.
how would you monitor voltage to the injectors? Would I have to cut into some wiring? On my diesel it’s got a dedicated module for the injectors that runs at 48v and you can monitor that voltage thru the computer.
This is revving it up in park btw.
(More useful data if you can monitor the injector circuit CURRENT at the fuse if you have access to an amp clamp and a scope.).
Can your FORScan display any injector data?
How about that “fuel injector fault” in post #1?
PS.... Calling all experts: Isn’t there a common problem with the fuse box fuse for the injectors, or is that for the fuel pump fuse, on these mid-year trucks?
Pulled the connector apart and found some bent pins. Also the plastic lock on the connector was broken and it was engaged fully. Bent the pins back, put in some dielectric grease and got it fully seated. Truck now runs great! The connector isn’t “snapped in” but I tugged on it and it doesn’t seem like it’s going to come apart rolling down the road. I tried putting a zip tie around it but couldn’t find a good way to lock it in.
Another clue. The oil pressure gauge had been reading zero for a long time. Truck obviously has oil pressure so we tried changing the sensor which didn’t fix anything. When the truck started this stalling the oil pressure gauge started coming back at times. Fixing the connector also fixed the oil pressure gauge.
Also in the first picture you can see how unplugged the connector was. Probably a good 1/4-1/2" unplugged. Gotta find a good way to lock that in. Tried a zip tie which was fine on the top, but at the bottom the wires are super close together and I would be pinching some which seemed counter-productive.
