Amp gauge
Old Jul 9, 2021 | 06:59 PM
  #31
Pappys53's Avatar
Pappys53
Originally Posted by hooler1
The other post would be going to a ground connection. So if you are running 12 volt negative ground, you simply ground it to a good ground.
So all in all, the new battery gauge postive connection goes to the 12 volt or battery voltage side of your 12v to 6v reducer, and your negative side of your gauge goes to a good ground. Then you are all done.
Thank you that makes sense. I have all my gauges hooked up now. On to the next section.
r2000f150
Jul 5, 2021 01:42 PM
Austy
Oct 23, 2010 09:14 AM
gene17847
22
May 8, 2008 10:54 PM
lshort
Electrical Systems/Wiring
Mar 27, 2002 12:56 PM
