Window Electrical Gremlin
Old Jul 1, 2021 | 11:10 AM
sauerkraut1's Avatar
sauerkraut1
Anybody else having this problem ??
My 2020 F-350 XL 7.3 CC LB 4x4, Rolled down it's own left and right front windows
as a thunderstorm passed over yesterday afternoon ..
This has happened 2 or 3 times in the past but old Mans syndrome had Me thinking
I left them down ..
Any Ideas ??
Every thing seems to still work correctly ..
Is there some way to pocket dial the key fob to cause this ??
I am going to make an appointment with the dealer, But probably can't get it in for a week or so ..
Thanks for any ideas !!
Old Jul 1, 2021 | 11:18 AM
Luke19_350's Avatar
Luke19_350
On my 2019 Platinum if you hold the unlock button on the fob for 3-4 seconds the front windows would roll down automatically. Might be getting pushed if you keep it in your pocket.
Old Jul 1, 2021 | 11:25 AM
sauerkraut1
I do keep the fob in My pocket, I will try that to see if it works the same way on My 2020 ..
Thanks !!
Unlock, lock or both buttons pushed for 8 to 10 seconds windows stay rolled up ..
Old Jul 1, 2021 | 11:30 AM
ford390gashog's Avatar
ford390gashog
Thanks !!
Global open windows are enabled from the factory. Press unlock twice and hold on the second press and the windows will drop. If you want to set global close it can be done with forscan.
Old Jul 1, 2021 | 11:43 AM
sauerkraut1
ford 390gashog;
Thank You ..
Can Global windows down be canceled in forscan ??
I'm hopping it can ..
I only seem to pocket dial this when its raining, Wet seats are no fun !!
Luke19_350
I tried it again with the key folded out and down the windows went !!
Thank You for the help no need to call the dealer ..
Hope this will help someone else out also Thanks Again !!
Old Jul 1, 2021 | 12:01 PM
cficare's Avatar
cficare
If it helps any, I keep a "key card" on my key ring positioned to cover the buttons while in my pocket. Never had anything on the truck activate since doing this.
Old Jul 1, 2021 | 12:44 PM
Mike_in_STL's Avatar
Mike_in_STL
I've set the panic alarm off more times than I can count with the keys in my pocket, but I've never rolled the windows down. I do know the global down command works though. Thanks for the "keycard" tip, I'm going to try this.
Old Jul 1, 2021 | 01:54 PM
ford390gashog
ford 390gashog;
Thank You ..
Luke19_350
Yes, in the BCM plain English setting disable global open windows.
Old Jul 1, 2021 | 04:38 PM
350Recon's Avatar
350Recon
Yes it happened to me with same year, truck, model and engine. Thought someone broke into it the night before when I found the windows down in the morning. Finally figured that I must have hit the button just right in my front pocket. At least it didn’t rain.
Maybe I should get a Glock holster for the key fob.
Old Jul 2, 2021 | 06:23 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I keep my key separate on a carabiner clipped to a belt-loop. I've never had an issue in 12-ish years I've owned vehicles with some type of "FOB"
My car is push button start, so I just throw the "FOB" in a lower cargo pocket and forget about it.
Old Jul 2, 2021 | 06:28 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Old Jul 4, 2021 | 09:10 PM
KU4OJ's Avatar
KU4OJ
For years I have carried my keys on a carabineer hooked to a belt loop. Makes the pants pocket last longer and keeps the keys from clawing my leg and other things. Never had a problem with fob doing weird things to the truck.
Old Jul 10, 2021 | 08:14 AM
sauerkraut1
Old habits die hard .. Sure like old fashion keys .. Can't pocket dial them ..
Normally used to carry a medium size handful of keys ..
This is only the second truck I've owned that had a FOB .. Did I say I really liked the old style keys !!
I guess they just fit My luddite life style !!
Thanks For The Help !!
I thought I had a lighting storm electrical problem ..
The Forum saved Me alot trouble !!
Thanks Again Steve ..
Rudefish
Feb 25, 2017 06:28 AM
bubbasz1
Jul 29, 2009 12:41 PM
f350ford17
Jan 4, 2008 08:40 AM
vanwhyjr
Jan 27, 2005 05:04 PM
