7.3L Gasser?
Old Jun 30, 2021 | 11:24 AM
Frogburner's Avatar
Frogburner
7.3L Gasser?
Been thinking about a 6.7 diesel or 7.3 gas motor. Pulling 8,500# camper currently but will the 7.3 be enough to pull a 12,000# if we decide to upgrade? Gas is definitely lower maintenance and we would prolly only be averaging about 8,000 miles per year only which 1or 2 thousand would be actual pulling. Thoughts everyone? I've heard the 7.3 is a monster motor also.
Old Jun 30, 2021 | 11:28 AM
Thevol's Avatar
Thevol
Easily, will use more fuel and rev higher than the 6.7 but can handle those loads you described just fine.
Old Jun 30, 2021 | 11:34 AM
scraprat's Avatar
scraprat
Top Answer: 5
Here's a subsection for the 7.3 gas engine.
https://www.ford-trucks.com/forums/forum307/
Old Jun 30, 2021 | 02:36 PM
Lakelover's Avatar
Lakelover
We are towing an 13000lb fifth wheel with our F20 7.3/4:30 gears and it tows like a boss! Drinks gas like a Boss as well!
Old Jun 30, 2021 | 02:56 PM
ScotD82's Avatar
ScotD82
What model is the 5th wheel? Is it 13000 GVWR, or is that the actual weight loaded for camping? I’ve got a 7.3/4.30 CCLB 11900lb GVWR F350 XLT on order and am trying to determine my limit for my next trailers size. I was looking at 14-15k as the max GVWR, leaning towards 14k. Also curious about your gas mileage towing. I get about 8 towing my 10000 GVWR travel trailer with my 6.2/3.73. I’m planning on about the same with the 7.3 and bigger 5th wheel.
Old Jun 30, 2021 | 02:57 PM
Lakelover's Avatar
Lakelover
Its a Cedar Creek 345IK
Old Jun 30, 2021 | 02:59 PM
Lakelover's Avatar
Lakelover
Its a Cedar Creek 345IK, getting around 8 MPG towing on fairly level roads.
Old Jun 30, 2021 | 03:57 PM
Germanrazor's Avatar
Germanrazor
Your current trailer will be okay easily. When you get up to what you are describing it can, but you will notice it more. The 7.3 is a beast no doubt. We have a TT but plan to one day get a 5’er around the 10,000 lb range or so.
Old Jul 1, 2021 | 09:48 AM
acadianbob's Avatar
acadianbob
Pulling a 12K GVW 5er that actually weighs about 10,750 loaded for camping. Get 9 MPG with 7.3 and 4.30's on two-lane 55/60 MPH highways in the midwest. Previous 6.2 with 4.30's got about 8 MPG "out West" in the heavier winds and at elevation. Expect the 7.3 to do about the same.
I'd probably max at a 14K GVW 5er and expect to actually pull 13K.
When we changed from the 6.2 to the 7.3, we also change from an F250 to an F350. I will say that the towing ride is better with the F350 and it handles the wind better.
Old Jul 1, 2021 | 10:10 AM
DaveZX's Avatar
DaveZX
7.3 gasser
Recommend F-350 at that weight. Payload is the main issue.
Old Jul 1, 2021 | 11:54 AM
sauerkraut1's Avatar
sauerkraut1
My 2020 XL F-350 7.3 CC LB Tows a 15,000 Jayco toy hauler at about 7 to 8 MPG
Depending on wind conditions ..
Empty is about 12-13 in town, 15 on the highway ..
Does a very good job of it !!
I'm very happy with the mileage loaded and empty ..
Old Jul 1, 2021 | 05:57 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The 7.3L sounds like a perfect fit for what you want to do.
Old Jul 2, 2021 | 06:41 AM
fordman19762003's Avatar
fordman19762003
I agree. With the trailer weights you'll be pulling and the low miles I wouldn't bother with a diesel.
T diesel
Jun 10, 2025 01:00 AM
hogryder007
Jan 12, 2025 08:24 AM
DALEDIESEL
Aug 10, 2020 08:29 AM
Calgarian
Feb 17, 2020 10:41 AM
bocomojoe
Large Truck
Sep 12, 2019 04:08 PM
