Vibration at higher speeds
Old Oct 30, 2003 | 04:39 PM
dbarracuda's Avatar
dbarracuda
Hey guys
I have a 77 f150 400/C6. Previously it would vribrate at 60+ mph. I took it in and the shop said it was the U-joints and the tailhousing bushing. I pulled the shaft and my mechanic said the u-joints were fine but i replaced tehm anyway cause they were original. Well now I drove it to Cottmans cause they rebuilt the tranny to have them check the bushing. On the way i notice the vibration was gone but i never went over 65 mph. They said it looked good. On the way home i brought it up to 75 and when i let off the gas the vibration was back. If i accelerated back to 70 it was gone. I dont think there was any under 65 either. I do have some slack in the rearend.
Any suggestions as to what this could be? Sorry for the long post but i thought ya'll need all the info.
Thanks
David
Old Oct 31, 2003 | 08:38 AM
LxMan1's Avatar
LxMan1
It could be from too much play in the rearend. You might want to check the driveshaft balance too, but if it changes with throttle position, then I would say it could be in the rearend. Make sure that the pinion nut is good and tight.
Jimmy
Old Oct 31, 2003 | 09:35 AM
dbarracuda's Avatar
dbarracuda
I have never messed with a rearend. How do i go about checking the pinion nut and where is it?
Thanks
David
