Window wash tank issue.
Old Jun 28, 2021 | 05:27 AM
mdwilliams44's Avatar
mdwilliams44
Trailering
So I have a question? I seem to have a leak in the window wash system. Fill it up and two days later the low fluid light is on. What really irks me, is that I cannot see a leak under the front end anywhere.
Ideas please? 2018 F250 6.7 King Ranch.
Old Jun 28, 2021 | 05:46 AM
B-ManFX4's Avatar
B-ManFX4
The low fluid light might be on but is the fluid actually low? The sensor might be at fault.
Old Jun 28, 2021 | 05:51 AM
mdwilliams44
Trailering
Good point
Yes the fluid appears to be empty. I am running an experiment to see if I can trace a leak, so any pointers are appreciated. Thanks for the tip on the sensor.
Old Jun 28, 2021 | 06:34 AM
BSHORT's Avatar
BSHORT
Top Answer: 5
Not seeing the leak is odd, as the tanks always seem to crack and everything just runs onto the ground.
Old Jun 28, 2021 | 07:39 AM
Mlarv's Avatar
Mlarv
Put red or blue food coloring in the tank of water. It should show up pretty easy after that.
Old Jun 28, 2021 | 07:47 AM
FOURBYBUD's Avatar
FOURBYBUD
Check your gill area by the front camera washer. Seen a few leaking from the check valve.
Old Jun 28, 2021 | 06:38 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The only issue I have with the washer fluid tank, is that it will not take a full gallon of fluid when it gets low Even my little-bitty Mazda 3 will take a full gallon...
Old Jun 28, 2021 | 06:39 PM
FOURBYBUD's Avatar
FOURBYBUD
Agreed. Why can't a 3 gallon tank be an option?
Transfer Flow do you hear us? 😂🤣😂🤣
Old Jun 28, 2021 | 06:44 PM
Tncdrew's Avatar
Tncdrew
good one! 🤣
Old Jun 28, 2021 | 07:26 PM
17350kr's Avatar
17350kr
I’ve had it where my front camera sprayer gets hooked on the grill and isn’t shut all the way and it drips out of it. I’d check there.
Old Jun 29, 2021 | 07:18 AM
mdwilliams44
Trailering
Thanks
I appreciate the tip.will try that for sure.
Old Jun 29, 2021 | 07:55 AM
jimzpsd's Avatar
jimzpsd
your fluid should already be blue or green, depending on the brand,................on a dry day it should be easy to find the leak
petrokiller
Feb 1, 2014 08:22 PM
stroker04
Jan 13, 2007 06:55 AM
tedandkathy
1997 - 2003 F150
39
Oct 18, 2002 01:21 PM
