Gearing questions
Old Jul 1, 2021 | 03:09 PM
Lrrr-RulerOfOmicronP's Avatar
Originally Posted by Christmas
I'm just trying to point out that when you go to freeway gears the around town town mpg's will suffer. To get the vehicle moving with higher gears are harder on the engine and takes more fuel. For me the off the line power is more important than some need to cruise at 75 mph in a truck that was never intended to do so. My 2020 tundra has 430 rear gears and works great to do it's intended purpose, granted it has overdrive. If I needed to go faster with less rpm's the transmission would be what I would change. You need to have it accelerate on demand, I live in the mountains and that is important to me.
Ok, I see what you are saying now and agree.
Old Jul 2, 2021 | 07:48 PM
351Cleveland C4's Avatar
351Cleveland C4
Absolutely. 3.73-4.30 gears are best if you have overdrive. (and 29-33” tires)
MPG isn’t dependent on RPM. It’s dependent on engine load.
I recently went from 3.55 to 4.56 gears in my bronco. MPG DID NOT CHANGE! Even though I’m turning 500 more RPM at 65 mph.
Old Jul 2, 2021 | 11:04 PM
load, engine rpm, and fuel efficiency are all relative.
This is a good read for how they are related: https://x-engineer.org/automotive-en...sumption-bsfc/
Every engine has its own BSFC map. A big block with low end torque will do very well running low rpm highway cruising with overdrive. If you are pulling a heavy load it may be better to drop a gear and run the rpm higher if fuel consumption is a concern.
Old Jul 3, 2021 | 12:42 AM
Christmas's Avatar
Christmas
I have not seen formulas like that since collage. Good read. To note the fuel efficiency is only 40% to start to with, that was interesting.
78Fords
26
May 9, 2021 10:26 PM
Matts56F100
Jun 25, 2018 09:12 PM
ASBCPASTOR
Mar 11, 2014 11:01 AM
MEPR
13
Apr 22, 2006 01:59 PM
I_Thnk_Ford
19
Apr 2, 2006 02:02 PM
