390 with Toploader
Old Jun 25, 2018 | 01:31 PM
Matts56F100's Avatar
Matts56F100
390 with Toploader
Im currently building a F100. I have a 390 and a 4 speed top loader. Both out of a 68 Galaxie. With that combo, will 4:10 gears in the rear be a good idea? Its not a drag truck, I just want to cruise with it. I'm not sure what for tires I'm going be running, something close to OEM. Please dumb it down, I'm not an expert when it comes to ratios and gears.
Old Jun 25, 2018 | 05:51 PM
tinman52's Avatar
tinman52
Welder User
You can play with a ratio calculator........plug in your numbers.....watch the RPM's. 4.10's would be fun at stoplights but really annoying at highway speeds. With OEM size tires I'd go with a 3.50ish ratio
https://www.randysworldwide.com/calculators/rpm/
Old Jun 25, 2018 | 08:27 PM
firstrider's Avatar
firstrider
Have 3;50's in "Art" the hot rod truck . It has a 428 , C-6 w/ a 3000 rpm stall converter and a '70 nine inch w/ those gears . Am very happy w/ this ratio . You are going to have a ton of fun w/ the BB FORD FE power plant . You will be surprised aw/ the power . "Art " is a blast to drive .
Old Jun 25, 2018 | 09:12 PM
Flat Ernie's Avatar
Flat Ernie
The Toploader is arguable the best factory 4-speed out there, but like all 4-speeds, the final drive is 1:1 - 1RPM in = 1RPM out. So, with a 4.10 rear end ratio and a fairly 'standard' 275/75R15 tire, with a nominal diameter of 31.25", at 70MPH, that big 390 is going to be spinning about 3300 RPM. That's a little on the uncomfortable side on the highway - those big FE engines don't like to turn those RPMs (I used to have a 428SCJ with 4:30 rear gears behind a toploader - 55mph was not comfortable on a long trip).
What you have going for you, however, is the low end torque of the 390. You can comfortably run a much higher (lower numerically) gear like a 3.25 or a 3.50. With a 3.25 rear gear, you'd only be turning about 2600 RPMs at 70MPH - much better. And even the 3.50 will only have you turning a little over 2800 RPMs at 70MPH.
ASBCPASTOR
Mar 11, 2014 11:01 AM
jimcar-9
44
Nov 11, 2013 01:39 PM
70_F250_390
Oct 24, 2011 04:25 PM
Morrisman
Jun 21, 2008 04:37 PM
pronstar
Jan 22, 2007 11:59 AM
