Truck will not turn over, need code help please
Old Jun 27, 2021 | 10:20 AM
Sligo's Avatar
Sligo
Exclamation Truck will not turn over, need code help please
Hi, New to the forum and hoping someone can give me some insight to the codes my truck is showing. To give a short back story, it died completely including the instrument panel while backing out of my driveway. I trouble shot the issue with a friend and replaced the accessory delay relay, fuel pump relay and PCM relay with no luck. I then went through the interior fuse box and found the ignition control fuse blown. Replaced that which gave me power back at the instrument panel and was able to run my OBD2 scanner. I also checked for corrosion and faulty wiring at the battery and starter, both are fine. I recently replaced the fuel pump, and fuel filter as well. The codes I'm getting are P0091, P0627, P0090, P0001. Does anyone have any insight as to what to check next?
Old Jun 28, 2021 | 04:31 AM
TheMeatShovel's Avatar
TheMeatShovel
4wd Low
Just doing a quick Google search of the codes you posted would tell me to check that new fuel pump you put in. Sounds like you have an open circuit/short somewhere. Double check all the connectors.
Old Jun 28, 2021 | 01:12 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Have the batteries load tested.
DSMTJ
Mar 24, 2023 12:01 PM
javila88
Oct 8, 2018 08:19 AM
stickbow95
Jan 19, 2017 02:44 PM
99f250craig
Aug 21, 2013 03:23 PM
fenix1
Apr 20, 2011 07:45 AM
